OPENSSL errors
i used the tarball nios2-linux-20090730.tar
and i wanted to used the openssl for net-snmp v3
the make menuconfig setting is :
uClinux Distribution Configuration
Network Applications --->
[*] openssl
some errors when make :
[ ! -d "openssl" ] || ( touch openssl/.sgbuilt_user && make -C openssl ) || exit $?
make[3]: Entering directory `/nios2-linux_snmp/uClinux-dist/user/openssl'
make -C /nios2-linux_snmp/uClinux-dist/lib/libssl all_user
make[4]: Entering directory `/nios2-linux_snmp/uClinux-dist/lib/libssl'
make[4]: *** No rule to make target `all_user'. Stop.
make[4]: Leaving directory `/nios2-linux_snmp/uClinux-dist/lib/libssl'
make[3]: *** [all] Error 2
make[3]: Leaving directory `/nios2-linux_snmp/uClinux-dist/user/openssl'
make[2]: *** [openssl] Error 2
make[2]: Leaving directory `/nios2-linux_snmp/uClinux-dist/user'
make[1]: *** [all] Error 2
make[1]: Leaving directory `/nios2-linux_snmp/uClinux-dist/user'
make: *** [subdirs] Error 1
[root@localhost uClinux-dist]#
What is wrong ? and what should I do ?
thanks for you help!
arens
Hi Arens,
I had the same problem here. Did you solve this problem eventually? How?
Best.
