Opencores (IGOR) problem
I am trying to make a linux kernel (2.6.x) on Altera NIOSII, everything works correctly (I can create an image with default options) but... but when I check field Opencores (IGOR) Emac Support in Kernel Configuration (I tried it with Ethernet 10 or 100Mbit enabled and later disabled) and "make" I see the following error:
make -C tools/ucfront
make[1]: Entering directory `/home/mk/mgr/uClinux-dist/tools/ucfront'
make[1]: Nothing to be done for `all'.
make[1]: Leaving directory `/home/mk/mgr/uClinux-dist/tools/ucfront'
ln -sf /home/mk/mgr/uClinux-dist/tools/ucfront/ucfront tools/ucfront-gcc
ln -sf /home/mk/mgr/uClinux-dist/tools/ucfront/ucfront tools/ucfront-g++
ln -sf /home/mk/mgr/uClinux-dist/tools/ucfront/ucfront-ld tools/ucfront-ld
make ARCH=nios2nommu CROSS_COMPILE=nios2-linux-uclibc- -j1 -C linux-2.6.x zImage || exit 1
no emulation specific options.
make[1]: Entering directory `/home/mk/mgr/uClinux-dist/linux-2.6.x'
scripts/kconfig/conf -s arch/nios2nommu/Kconfig
block/Kconfig:36:warning: 'select' used by config symbol 'BLK_DEV_IO_TRACE' refer to undefined symbol 'DEBUG_FS'
make[1]: Leaving directory `/home/mk/mgr/uClinux-dist/linux-2.6.x'
CHK include/nios2_system.h
perl -I/home/mk/mgr/uClinux-dist/linux-2.6.x/arch/nios2nommu/scripts /home/mk/mgr/uClinux-dist/linux-2.6.x/arch/nios2nommu/scripts/gen_nios2_system.h.pl nios2 sdram flash < /home/mk/mgr/quart/eth_vip_cyc.ptf > include/nios2_system.h.tmp; if [ -r include/nios2_system.h ] && cmp -s include/nios2_system.h include/nios2_system.h.tmp; then rm -f include/nios2_system.h.tmp; else echo &#39; UPD include/nios2_system.h&#39;; mv -f include/nios2_system.h.tmp include/nios2_system.h; fi
CHK include/linux/version.h
CHK include/linux/utsrelease.h
CHK include/linux/compile.h
GEN usr/initramfs_data.cpio.gz
AS usr/initramfs_data.o
LD usr/built-in.o
CC arch/nios2nommu/kernel/setup.o
arch/nios2nommu/kernel/setup.c: In function `setup_arch&#39;:
arch/nios2nommu/kernel/setup.c:325: warning: implicit declaration of function `paging_init&#39;
LD arch/nios2nommu/kernel/built-in.o
CC drivers/net/Space.o
drivers/net/Space.c:204: error: `oeth_init&#39; undeclared here (not in a function)
drivers/net/Space.c:204: error: initializer element is not constant
drivers/net/Space.c:204: error: (near initialization for `isa_probes[0].probe&#39;)
drivers/net/Space.c:204: error: (near initialization for `isa_probes[0]&#39;)
drivers/net/Space.c:260: error: initializer element is not constant
drivers/net/Space.c:260: error: (near initialization for `isa_probes[1]&#39;)
make[3]: *** [drivers/net/Space.o] Error 1
make[2]: *** [drivers/net] Error 2
make[1]: *** [drivers] Error 2
make[1]: Leaving directory `/home/mk/mgr/uClinux-dist/linux-2.6.x&#39;
make: *** [linux] Error 1
At line 204 in file Space.c I can see:# if defined(CONFIG_OPEN_ETH)
{oeth_init, 0},# endif
What do I do wrong ? I am a beginner so everything is new for me...
Thank you for your response in advance,
With Regards,
Koza
Please update Space.c,
Index: Space.c =================================================================== --- Space.c    (revision 31) +++ Space.c    (revision 32) @@ -73,6 +73,8 @@ extern struct net_device *SK_init(int unit); extern struct net_device *seeq8005_probe(int unit); extern struct net_device *smc_init(int unit); +extern struct net_device *oeth_init(int unit); +extern struct net_device *mtip1000_init(int unit); extern struct net_device *dm9ks_probe(int unit); extern struct net_device *atarilance_probe(int unit); extern struct net_device *sun3lance_probe(int unit);
Please attach your ptf in the wiki, so that I can test the build with open eth in the future.
http://nioswiki.jot.com/wikihome/operatingsystems/ethernet (http://nioswiki.jot.com/wikihome/operatingsystems/ethernet)
TO_BE_DONE
