PCI in uClinux
Does suported PCI in uClinux for NIOS II with Altera PCI Compiler 4.0 pci_mt_32 megafuntion ?
Anywho uses this options ?
I can't compile kernel with PCI support...
http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/sad.gif
Thnx...
Update:
The Ethernet on PCI solution now reaches 70MBit on a 100MBit Network with TCP/IP.
Therefore i think that is a very good value under uClinux and with SDRAM@100MHz
Next i try it with DDR-Ram.
Bye
Marco
