12746 Discussions
PCIe Memory Write/Read abnormal behavior
We have a PCIe core that is configured as a rootport. It is connected
to a switch which has a single device on the downstream side. We
enumurated the PCIe busses successfuly and moved on to memory IO
mapping. the device has 1MB memory and we configured its base address
to 0x40000000. We set The command register to 6, enabling memory space
and bus master.
The downstream bridge, connected to the device, memory base/limit
register is set to 0x40004000, so as the upstream bridge connected to
the root-port. All have memory space and bus master enabled.
Now we are facing 2 problems:
1. We can write to/read from even addresses of double-words (0x00,
0x08, 0x10, etc.), but when we read from odd DW addresses (e.g. 0x04,
0x0c, etc.) we receive only the header of the TLP packet (indicating 1
DW, 4 bytes) but no data is available on the FIFO.
2. When we write memory with multiple words payload we read back old
data, i.e. the memory write did not take place at all.
PCIeFnWriteMemory32: requester_id 0000 (0,0,0), tag 1F, target_addr
40000100 , data 123ABCDE
TX Data = 0x40000001
TX Data = 0x00001f0f
TX Data = 0x40000100
TX Data = 0x00000000
TX Data = 0x123abcde
40000104 , data 12ABCDEF
TX Data = 0x40000104
TX Data = 0x12abcdef
PCIeFnReadMemory32: requester_id 0000 (0,0,0), tag 1F, target_addr 40000100
TX Data = 0x00000001
RX Data = 0x4a000001
RX Data = 0x09000004
RX Data = 0x00001f00
RX Data = 0x00000000
RX Data = 0x123abcde
completion status 0, Successful Completion (SC)
PCIeFnReadMemory32: requester_id 0000 (0,0,0), tag 20, target_addr 40000104
TX Data = 0x0000200f
RX Data = 0x00002004
RX FIFO is empty !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Has anyone encounter such behavior? Any ideas?
S.
Found the problem ! The TX packet has two extra DW of 0x00000000 which must not be there. This violates the memory write spec. for 32bit access. So, instead
of:
it should be:
The SW guy has a red face now...
S. (HW guy)
