PIO Vs. Avalon ?!
hi....i&#39;m using a niosII processor and I wanna add a hardware block external to the processor and on the same FPGA that performs a general function (eg, Vector dot product). Should I interface it to the processor using the avalon bus or can i interface to a PIO block that&#39;s already interfaced to the avalon bus? http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/unsure.gif
thnx
Hi wesam,
I started a design using a PIO for address, a PIO for control, and a PIO for
data. I quickly changed my mind once I started writing the device driver
code -- it was much more time-efficient (and MIPS efficient) to just write a
simple avalon interface. Later, I decided I needed DMA support ... and it
basically came "for free" since I already had the avalon interface.
In general, if you&#39;re doing more than just twiddling a few bits, you should
consider the avalon interface. One way or another, you&#39;ll end up writing the
interface logic anyway-- whether it&#39;s in an HDL or in C ... but the HDL
strategy comes with some built-in "freebies" ;-)
--Scott
thnx a lot,
so, are the &#39;Create New Component&#39; and the &#39;Interface to User Logic&#39; in SOPC implement an avalon interfaced device or just any general device?
thnx
The interface to user logic will create the avalon interface for your logic.
You&#39;ll have to select address width, data bus width, etc. as appropriate.
--Scott
I should be more clear ... sorry:
The interface to user logic will export the avalon bus signals from the
system module that your custom logic connects to.
--Scott
thanks a lot
