12748 Discussions
Performance Counter Issues Urgent!!
Hi All,
I have some serious problems in usage of performance counters, could anyone please let me know what could have gone wrong.
I have included the associate header files. Some junk value is coming ,dont know why. Some data corruption had happened, or the prints not working.
nios2-terminal: (Use the IDE stop button or Ctrl-C to terminate)
ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
--Performance Counter Report--
Total Time: seconds (1993414581 clock-cycles)
ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
Ravi MS
<div class='quotetop'>QUOTE (ittiam @ Jul 12 2009, 04:46 PM) <{post_snapback}> (index.php?act=findpost&pid=23086)</div>
--- Quote Start ---
Hi All,
Ravi MS[/b]
--- Quote End ---
try using like this
int main()
PERF_RESET(PERFORMANCE_COUNTER_1_BASE);
PERF_START_MEASURING(PERFORMANCE_COUNTER_1_BASE);
call your function here
PERF_STOP_MEASURING(PERFORMANCE_COUNTER_1_BASE);
alt_u64 time2 = 0;
time2 = perf_get_section_time((void *)PERFORMANCE_COUNTER_1_BASE, 1);
printf("IT TOOK T1: Main Loop : %d cycles\n", time2);
in your function say
multiply()
PERF_BEGIN(PERFORMANCE_COUNTER_1_BASE,1);
you code for perfomance here
PERF_end(PERFORMANCE_COUNTER_1_BASE,1);
select how many section you want o measurein perfomance counter unit.
anand
My program looks like this , certainly something is wrong, could you anyone let me know the details.
if (inverse)
PERF_RESET(PERFORMANCE_COUNTER_0_BASE);
PERF_START_MEASURING(PERFORMANCE_COUNTER_0_BASE);
PERF_BEGIN(PERFORMANCE_COUNTER_0_BASE,1);
scale = fix_fft(fi, fr, m-1, inverse);
PERF_END (PERFORMANCE_COUNTER_0_BASE,1 );
PERF_STOP_MEASURING(PERFORMANCE_COUNTER_0_BASE);
perf_print_formatted_report ((void *)PERFORMANCE_COUNTER_0_BASE, /* defined in "system.h" */
ALT_CPU_FREQ, /* defined in "system.h" */
1, /* How many sections to print */
"INVERSE FFT"
//sw_time_1 = alt_timestamp();
for (i=1; i<N; i+=2)
tt = f[N+i-1];
f[N+i-1] = f
f = tt;
if (! inverse)
"FFT"
Ravi MS
<div class='quotetop'>QUOTE (anapar @ Jul 14 2009, 04:26 PM) <{post_snapback}> (index.php?act=findpost&pid=23105)</div>
--- Quote Start ---
--- Quote End ---
--- Quote Start ---
Hi All,
Ravi MS[/b]
--- Quote End ---
try using like this
int main()
alt_u64 time2 = 0;
multiply()
anand
[/b]
--- Quote End ---
Same Problem here...
I think the problem is the perf_print_formatted_report.
If I choose the "Small C Library" the code works. If not, then there is the garbage.
Also if you look at the perf_print_formattec_report.c the Nios IDE complains that there are syntax errors.
Anybody got a workaround?
So check the "Small C Library" option and build the project, and then uncheck it, build the project again, the counter_report will work fine.
