Performance Counter
Hi. I have a problem, I am trying to use the "Performance Counter" for general time measurements. In the documentation there is an example how to use it, so I have used it as a base for my tests. However, I don't get the results I expected. For example, the line C-code "i=3;" takes 104 clock ticks to execute?!
My code:
# include <stdio.h>
//For the performance counter # include "altera_avalon_performance_counter.h"# include "system.h"
# define FUNCTION_SECTION_1 1# define FUNCTION_SECTION_2 2
void function_1 (void)
int i=0;
//PERF_COUNTER_0_BASE is defined in system.h
PERF_BEGIN (PERFORMANCE_COUNTER_0_BASE, FUNCTION_SECTION_1);
i=3; //First Object to measure
PERF_END (PERFORMANCE_COUNTER_0_BASE, FUNCTION_SECTION_1);
void function_2 (void)
int i=0;
PERF_BEGIN (PERFORMANCE_COUNTER_0_BASE, FUNCTION_SECTION_2);
i=3; //Objects to measure
i=4;
PERF_END (PERFORMANCE_COUNTER_0_BASE, FUNCTION_SECTION_2);
//Turn measurement on & off
int main()
// Reset the counters before every run
PERF_RESET (PERFORMANCE_COUNTER_0_BASE);
// Now our program starts in earnest. Begin measuring:
PERF_START_MEASURING (PERFORMANCE_COUNTER_0_BASE);
function_1();
function_2();
PERF_STOP_MEASURING (PERFORMANCE_COUNTER_0_BASE);
//Print the result using "perf_print_formatted_report"
ALT_CPU_FREQ, // defined in "system.h"
2, // How many sections to print
"function 1",
"function 2"); // Display-name of section(s).
return 0;
From this code I get the following results:
--Performance Counter Report--
Total Time: 1.64167E-05 seconds (788 clock-cycles)
| Section | % | Time (sec)| Time (clocks)|Occurrences|
|function 1 | 13.2| 0.00000| 104| 1|
|function 2 | 19.3| 0.00000| 152| 1|
What does it means? What have I done wrong?
/David
