12748 讨论
Pointing IDE to different folders...
名誉分销商 II
1,293 次查看
This is a very basic question.
How do I point the IDE to a new but existing project.
The scenario is that someone sends me a quartus/SOPC/NiosII/IDE project tree and I unzip it onto my local drive. I have my own project(s) in the IDE pointing to other systems and they work fine.
How do I repoint to this new, but existing project I've been sent?
Or maybe another way to ask is to how do I open this project? I don't want to create anything new, I just want to open an existing project and start workiing with it.
Ken
0 项奖励
6 回复数
名誉分销商 II
579 次查看
I'm not sure if I understand your question, but have you tried "File->Import project" ?
0 项奖励
名誉分销商 II
579 次查看
Yeah, I select the project and it gives an error saying "Project Already Exists". Go figure http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif
Ken
0 项奖励
名誉分销商 II
579 次查看
Import them one at a time (I hope they didn&#39;t send you 30 projects or this will take a while). Once you have imported the application project and the system library it is associated to you are all ready to go.
0 项奖励
名誉分销商 II
579 次查看
Sounds like the projects have the same name. If that&#39;s not the case look at the navigator and C/C++ projects trees (it may be in only one of them)
0 项奖励
名誉分销商 II
579 次查看
if you already have a project with that name, you cannot import it again.
either do
- you first have to delete the existing project from the navigator (you must not delete it from the hd, "do not delete contents")
- rename the project you want to import by manually changing the name in file .project
0 项奖励
名誉分销商 II
579 次查看
Well I&#39;ve gotten closer. I deleted all the projects I had (I&#39;ll have to deal with that problem later) and imported both the project and syslib projects one at a time as BadOmen suggests. Seems to go well, but a build/rebuild gives an error that the .ptf is needed:
the entire error is:
"*** No rule to make target `C:\qdesigns\neuralog\stratscan\stratscanner.ptf&#39;, needed by `C:/SRC/2004/stratscan/software/hello_world_0_syslib/Debug/system_description/../obj/generated_app.mk-t&#39;. Stop."
The .ptf file is now in C:/SRC/2004/stratscan. This is set correctly in the System Library Properties, so I don&#39;t know why its looking in C:\qdesigns.
Where else do/can you set the .ptf location?
It would be real nice if I could just Open Project..., Browse for a/the project file and go to town. Too much to ask I guess...
Ken
0 项奖励
回复
