12745 Discussions
Port dillo2 on uclinux with nios2
Hi,everyone.I have ported Dillo2 on my DE2-70 with uclinux,Although</SPAN></SPAN> there is still some problems.
dillo2 need:
libjpeg
libpng
libiconv
microwindows
nxlib-0.45
fltk2
libjpeg&#12289;libpng&#12289;microwindows&#12289;nxlib are already in nios2-linux-20090730.tar&#12290;
Libiconv&#65306;http://www.gnu.org/software/libiconv/
Libiconv port on nios may meet the problem&#65288;machine 'nios2' not recognized&#65289;. I don`t want to spend too much words on it,Anyone who wants to know how to fix it,plz give me a e-mail&#65288;pc21820002000@yahoo.com.cn&#65289;.
FLTK2:
CFLAGS="-G 0 –I /mynios/nios2-linux/uclinux/staging/usr/include" CXXFLAGS="-G 0 –I /mynios/nios2-linux/uclinux/staging/usr/include /.." LDFLAGS="-s –L /mynios/nios2-linux/uclinux/staging/usr/lib –elf2flt" ./configure --host=nios2-linux-uclibc --target= nios2-linux-uclibc –disable-shared --with-x --disable-gl --disable-cygwin --x-includes=../ --x-libraries= /mynios/nios2-linux/uclinux/staging/usr/lib --cache-file=/dev/null
modify fltk2-xonfig and makeinclude
replace all -lXi –lXext into -lX11 -lnano-X
then make
&#65288;maybe still some problems in nxlib, find stub.c in your nxlib,and use mine instead?&#65289;
DILLO2:
find libz.a libiconv.a libfltk2.a and move them to /usr/local/lib
Modify configure
{ echo "$as_me:$LINENO: checking FLTK2" >&5
echo $ECHO_N "checking FLTK2... $ECHO_C" >&6; }
if sh -c "$FLTK2_CONFIG --version" >/dev/null 2>&1
then { echo "$as_me:$LINENO: result: yes" >&5
echo "${ECHO_T}yes" >&6; }
LIBFLTK_CXXFLAGS=`$FLTK2_CONFIG --cxxflags`
LIBFLTK_CFLAGS=`$FLTK2_CONFIG --cflags`
LIBFLTK_LIBS=`$FLTK2_CONFIG --use-images --ldflags`
else { echo "$as_me:$LINENO: result: no" >&5
echo "${ECHO_T}no" >&6; }
{ { echo "$as_me:$LINENO: error: FLTK2 must be installed!" >&5
echo "$as_me: error: FLTK2 must be installed!" >&2;}
{ (exit 1); exit 1; }; }
fi
Replace all fork into unfork
FLTK2_CONFIG=/fltk2/fltk2-config PNG_CONFIG=/mynios/nios2-linux/uclinux/lib/libpng/libpng-config
LDFLAG=”-elf2flt” ./configure --host=nios2-linux-uclibc --target= nios2-linux-uclibc --cache-file=/dev/null
OK,now,have fun~~ ^_^
