Porting uClinux
Hi all
I want to port uClinux to my own board ( ie: Stratix ).
There are some steps to do this:
1. Adding vendor name, board name, files:
uClinux-dist / vendors / vendor_name / board_name /
config.arch
config.linux-2.4.x
config.linux-2.4.x.initrd
config.linux-2.4.x.jffs2
config.uClibc
config.vendor-2.4.x
config.vendor-2.4.x.jffs2
dev.txt
inittab
Makefile
motd
passwd
rc
2. Adding cpu name, platform opcode:
uClinux-dist / linux-2.6.x / arch / cpu_name /
kernel /
lib /
mm /
scripts /
ChangeLog
defconfig
Kconfig
Makefile
and:
What documents or starting point for writting the above folders / files. I want to understand them in detail. What should I do ?
Thank you,
OneNet
Hi all !
In the source code of Microtronix package , some files are in the folder:
nios2linux-1.4/plugins/com.microtronix.nios2linux.kernel_1.4.0/linux-2.6.x/arch/nios2nommu
having:
# include <linux/stddef.h># include <linux/sched.h># include <linux/kernel_stat.h># include <linux/ptrace.h># include <asm/bootinfo.h># include <asm/irq.h># include <asm/hardirq.h># include <asm/nios.h>
- I searched and could not find those folders (linux/ , asm/ ) / files ( nios.h ).... Where are they ?!
- If I want to re-compile Microtronix&#39;s kernel without NIOS IDE, What should I do ?!
Thank you,
OneNet
