12748 Discussions
Posix thread priority and scheduling..
I would like to create 4 threads, with the following attributes
SCHED_FIFO
thread 1 has priority value of 99
thread 2 of 99
thread 3 of 50
thread 4 of 20
(where the higher the number, the higher the priority. thus higher priority thread should preempt lower priority thread)
So I wrote this code:
   pthread_attr_t thread_attribute;    pthread_t      thread_id;    struct sched_param thread_param;        thread_param.sched_priority = 40;        printf("priority %d\n", thread_param.sched_priority);        pthread_attr_init( &thread_attribute );    pthread_attr_setdetachstate( &thread_attribute, PTHREAD_CREATE_DETACHED );    pthread_attr_setschedpolicy( &thread_attribute, SCHED_FIFO );    pthread_attr_setschedparam(  &thread_attribute, &thread_param );    printf("current prio: %d\n", pthread_attr_getschedparam(  &thread_attribute, &thread_param ));    sched_setscheduler( 0, SCHED_FIFO, &thread_param );    printf("current prio: %d\n", pthread_attr_getschedparam(  &thread_attribute, &thread_param ));
What I see on the screen is the prority value is 0 and 0. Am I setting the thread priority value the right way? Has anyone been able to change the scheduling policy and thread's priority?
Hi ShaChris23,
pthread_attr_getschedparam doesn't return the _priority_, it returns zero on success, non-zero
otherwise. You need to look at the returned thread_param.
--Scott
