12748 Discussions
Possible Bugs in Eclipse Project BSP
SeanAB
Quartus Prime Lite Ver 21.1.0 Build 842 10/21/21 - Windows 10 Host system
Eclipse Mars.2 rel 4.5.2
When the Eclipse BSP project files are created, I keep see inga couple errors pop-up in the BSP source files.
#1 alt_read.c
Line 120 appears to have an error:
ALT_ERRNO = EBADFD;
should be
ALT_ERRNO = 0xEBADFD;
#2 alt_sys_inti.c - when a Timer is added to the design
Line 74 - shows alt_no_storage is undeclared refers to the following in
alt_avalon_timer.h calls this out:
#define ALTERA_AVALON_TIMER_INSTANCE(name, dev) extern int alt_no_storage
Am I supposed to set this value to something?
hareesh
Hi SeanAB,
can you please share your plat form design screen shot and .sopcinfo file.
thanks,
SeanAB
Attached are the request file. Not sure if these are bugs or not. The application runs just fine, but the BSP showing bugs is a little puzzling.
hareesh
Hi @SeanAB,
With your shared .socpinfo file, I recreated the eclipse project. I haven't seen any problems when I build a complete project. you can  see console window output in bellow attachment. Once, update your Quartus software and try it.
SeanAB
The issues is in Eclipse. In the HAL source alt_read.c file, the attached bug appears. Again not sure if this is really an bug as the application builds and runs without issue.
hareesh
Hi @SeanAB ,
just disable the Symbol is not resolved option in code analysis section. go through the reference link and attachment.
link:
https://www.intel.com/content/www/us/en/support/programmable/articles/000084712.html
