12748 Discussions
Powerdown Arria II in Chain Design
I'm designing a board with two Arria IIs on it. They will be configured
in Passive Serial Configuration as shown in page 9-23 of "Arria II GX Device Handbook Volume 1".
We may have just Device 1 running sometimes and leave Device 2 consuming
the least amount of power possible.
What is the recommended design to minimize Device 2 power consumption? Would somehow preventing the second device to be configure the best solution?
Does the 2nd Arria II share all power supplies with the 1st?
Jake
Yes. They are all connected to the same power supply.
If you're willing to have different regulators/converters for each FPGA, you can disable the outputs for the 2nd FPGA and thus, cut it's power supply.
Reseting the device, by pulling the nCONFIG pin low, is problably the next most effective method.
However, in either case, you'll have to re-configure the 2nd FPGA every time you "wake it up".
In any case, you can also apply the usual techniques to reduce power consumption are
a) use as low as possible clock frequencies
b) make use of clock enables
c) make use of gated clocks (beware of issues with gated clocks)
d) power-down GX blocks
Keeping PLLs in reset (assuming internal clocks are supplied by a PLL) should be sufficient to stop most clocked device activities.
