12748 Discussions
Problem Downloading in Nios IDE
I am trying to program is simple "Hello World" program into a Nios II running in a Cyclone (EP1C6T144) which is on a custom board. I'm using Quartus 5.0 and the USB byte-blaster. When I select "Run As - Nios II hardware" I get the following message.
There are no Nios II CPUs with debug modules available which match the values
specified. Please check that your PLD is correctly configured, downloading a
new SOF file if necessary.
I'm able to download the .sof file from the Quatus II programmer just fine so I'm pretty sure that the JTAG is working well. I made sure that the IDE project points to the right .ptf file and the Nios II in SOPC has a level 1 debug module. What values is the error message referring to? I tried taking out the system ID from SOPC Builder.
I read on another posting that there might be an issue with the TCK line and that a simple RC with 100pF and 32ohm might help. I tried that without success. Can you think of what might be stopping the .elf file from being downloaded?
Danny
Hi Danny,
My two cents would be to:
1. Try a JTAG if possible and see if you get the same message
2. Try rebooting your machine, sounds hokey, but I have seen this work
3. Try a different CPU, Like The Lower Performance/ Also play wiht debug levels
4. Make sure memory is targeted correctly, check system properties.
-Baycool
It looks, to me, like you've not programmed your FPGA or you have no debugger built into your processor, though you clearly state that you have. What does a "jtagconfig -n" command return from within the SDK shell? You should see something like this:
$ jtagconfig -n 1) USB-Blaster  020840DD   EP1C20    Node 11104600    Node 0C006E00
The two "nodes" listed, above, are the debugger and the jtag_uart, in my case.
Also, make sure you're not using an OCP version of the processor, as that requires that you keep the programmer open.
Cheers,
- slacker
I've tried everything that Baycool suggested and still nothing. I've put together a second board and it is acting the same way. When I did the jtagconfig -n command in the SDK shell I get the first two lines correctly followed by 30 nodes! I only have one Cyclone FPGA and as far as I know I only have one Nios II. What could cause that?
I've been fighting this Nios problem for a while now. When I first tried to program the Cyclone through the JTAG port, the Quartus II programmer would not program the Cyclone and return the message that "Config_done does not go high". Only after I programed a .pof file into the EPCS flash (thereby loading the configuration using active serial) was I able to program the cyclone through the JTAG. Could these two seemingly unrelated problems have a common link?
Rgds,
Danny
You've got JTAG hardware issues. Take a look at one of the Nios II Dev. board's schematic.... It should steer you in the right direction.
Cheers,
- slacker
I layout the JTAG as:
TCK pulled low with 10K ohm
TMS,TDI pulled high with 10K ohm
TDO floated ( I saw someone pllued high)
other signals for downloads:
FPGA_CONF_DONE,FPGA_STATUSn pulled high with 10K ohm
I tested TDO pllued high, It worked, too. Which one is the best choice?
Thank everyone for all of the suggestions. It turns out that I did have a JTAG problem as some of you pointed out. It wasn't a schematic issue but rather a problem with my layout. The solution ended up being a couple of decoupling caps right next to the JTAG header power pins. I used 1uF in parallel with 1000pF. Apparently I was getting some noise in the JTAG signals. I haven't had any problems since.
Danny
