12748 Discussions
Problem creating NIOSII BSP and Application from template
I am trying to work on this tutorial: altera.com/literature/tt/tt_nios2_tcpip.pdf
So, I select New -> NIOSII Application and BSP from template -> enter the SOPC information File Name and project name(sample_socket_server_0), select a 'blank project' template and click Next ->
Here, since I want to use MicroC, I click on Select an existing BSP from your workspace and "create"
Here, I change the OS to MicroC, name it (sample_socket_server_0_bsp) and say "Finish".
It finishes building the bsp (I can see it in the Project explorer as sample_socket_server_0_bsp) and closes the dialog box, but the "Finish" button in the "NiosII Application and BSP from template" is never highlighted so I cannot create the application.
Does anyone have any idea why this can happen? And how it can be solved? Any help would be great.
thanks a lot
