12747 讨论
Problem dloading vmlinux to 2C35
名誉分销商 II
2,976 次查看
I was trying to download the vmlinux.flash image to the board and received this error
Using cable "USB-Blaster [USB-0]", device 1, instance 0x00
Resetting and pausing target processor: FAILED
(I get this immediately so it's not the same problem as the one described as happening after 20 seconds for which Altera's put out a fix for)
I used the standard.sof and std_2C25.ptf but I'm not sure whether that is the correct design to use for linux or whether we need to create our own sof?
Also, I'm wondering why my vmlinux.flash size was so large at about 8.3 mb? Is it supposed to be that size since I saw this in the toolchain setup thread:
Memory available: 63744k/65536k RAM, 0k/0k ROM (694k kernel code, 417k data)
Lastly, since the flash memory size isn't too big, is it possible to use the RAM instead of the flash for the kernel? Would I need to compile the kernel with different options in that case?
Thanks a lot in advance!
0 项奖励
15 回复数
名誉分销商 II
1,218 次查看
You can definitely download the kernel to RAM - just in the properties for the system library, make sure all the code/data locations are set to RAM instead of some sort of Flash. Then, to run, you can either download the .elf file directly using nios2-download, or clicking 'run as Nios II hardware'.. (or something like that).
0 项奖励
名誉分销商 II
1,218 次查看
the vmlinux.flash is S-record format, a kind of hex file. so it take up more space than the actual binary size.
the vmlinux elf file contains debug symbols, so it may reach 10M. you can use "xxxx-strip" to remove the symbols, and it should be around 2M.
You should try to download the elf to dram as a beginning.
0 项奖励
名誉分销商 II
1,218 次查看
I did a
strip --target=srec vmlinux
and the original 8314kb got skimmed down to 7685kb, which still seems quite big. Should I be using some other options?
And where is the system library I should be looking for to set to RAM rather than FLASH?
Sorry if the question seems a bit basic but if you don't mind giving step by step instructions for that?
Thanks a lot!
0 项奖励
名誉分销商 II
1,218 次查看
Finally, I borrowed a CycloneII dev board, and worked out.
You should have quartusII v5.1 sp1, and NiosII v5.1 sp1.
There is no need to strip the vmlinux.
First open the project and download the sof of your board with QuartusII programmer. eg, if you use CycloneII dev board,
it is altera/kits/nios2/examples/verilog/niosII_cycloneII_2c35/standard/ standard.sof
Next, open two "Nios II SDK shell" windows.
From one, run "nios2-terminal".
From two, run "nios2-download -g vmlinux"
0 项奖励
名誉分销商 II
1,218 次查看
I just tried that but I'm still getting the same error though
Resetting and pausing target processor: not responding
Resetting and trying again: FAILED
Leaving target processor paused
I'm trying this with the standard.sof from the CD but I'm using the DE2 Cyclone II 2C35 board which doesn't have ddr_sdram. I assume if I create my own design (ie .sof and .ptf) and use that .ptf I should be able to get the sdram option during hwselect when compiling the kernel?
Currently, I don't have an option for sdram with the std_2C35.ptf and it instead only gives the options for ddr_sdram, ext_ssram and epcs_controller for selecting a device ot execute the kernel from.
0 项奖励
名誉分销商 II
1,218 次查看
The DE2 is different from CycloneII dev board.
You can find in the kit dir,
DE2_System/DE2_demonstrations/DE2_NET
use file nios_0.ptf for kernel hwselect
use file DE2_NET.sof for the board.
0 项奖励
名誉分销商 II
1,218 次查看
Hi hippo,
I've got the DE2_NET.sof on the board. After that,
I tried using nios2-download:
and it shows
<div class='quotetop'>QUOTE </div>
--- Quote Start ---
Using cable "USB-Blaster [USB-o]", device 1, instance 0x00
Pausing target processor: OK
Downloaded 2563KB in 32.2s
Verified OK
Starting processor at address 0x0000000[/b]
--- Quote End ---
I assume it downloaded onto the board fine but the nios2-terminal I started doesn&#39;t show anything beyond this
--- Quote Start ---
connected to hardware target using JTAG UART on cable
<Used hte IDE stop button or Ctrl-C to terminate>[/b]
--- Quote End ---
How do I actually get to type in the uClinux commandline?
I also tried
nios2-elf-objcopy -O binary vmlinux vmlinux.bin bin2flash --location=0x0 --input=vmlinux.bin --output=vmlinux.flash nios2-flash-programmer --base=0x800000 vmlinux.flash
(I&#39;ve verified in the nios_system.h file that the cfi flash does indeed start at that address)
And it shows:
--- Quote Start ---
Resetting and pausing target processor: OK
Checksummed/read 1024kB in 22.9s
Erased 576kB in 20.1s
Program failed
Leaving target processor paused[/b]
--- Quote End ---
I&#39;m assuming this is happening because the vmlinux.bin is quite large ~2.5MB (cfi flash is only 1 MB) and I&#39;m not sure how to reduce that size by much (strip vmlinux only gets the vmlinux&#39;s original 8 MB down to about 7MB)
Would appreciate very much any direction you could give on this!
Thanks!
0 项奖励
名誉分销商 II
1,218 次查看
The previous steps to generate flash file was wrong. I will tell you about that later. Let first run it in ram.
Built the kernel with jtag uart. with minimal config first. and minimal rootfs.
cp ~/download/kernel.config .config
make ..... hwselect SYSPTF=....../nios_0.ptf
make ..... menuconfig
change Device drivers--> Char devices -> serial drivers -->
unselect Nios serial support,
select Altera JTAG UART support and support for console on Altera JTAG UART
exit and save
make .....
There is no need to do strip.
(if nios2-terminal is open, close nios2-terminal with control-C.)
Use Quartus to download the DE2_NET.sof to the board.
Open a nios2 sdk shell, (there is no need to open two sdk shell, one is OK).
(the nios2 does not run yet, it will wait for jtag uart on nios2-terminal)
then run "nios2-terminal"
0 项奖励
名誉分销商 II
1,218 次查看
Hi hippo,
Thanks, I got this after opening up nios2-terminal-
--- Quote Start ---
Linux version 2.6.11-uc0 (Ricky@localhost.localdomain) (gcc version 3.4.5)# 6 Sa
t Mar 4 20:28:04 EST 2006
uClinux/Nios II
Altera Nios II support © 2004 Microtronix Datacom Ltd.
Built 1 zonelists
Kernel command line:
PID hash table entries: 64 (order: 6, 1024 bytes)
Dentry cache hash table entries: 2048 (order: 1, 8192 bytes)
Inode-cache hash table entries: 1024 (order: 0, 4096 bytes)
Memory available: 5456k/8192k RAM, 0k/0k ROM (704k kernel code, 1912k data)
Mount-cache hash table entries: 512 (order: 0, 4096 bytes)[/b]
--- Quote End ---
seems like linux is now on the board but it seems to go into some kind of weird loop where it keeps outputting the following:
--- Quote Start ---
Free pages:        0kB (0kB HighMem)
Active:1023 inactive:148 dirty:0 writeback:0 unstable:0 free:0 slab:191 mapped:0
pagetables:0
DMA free:0kB min:0kB low:0kB high:0kB active:4092kB inactive:592kB present:8192k
B pages_scanned:2552 all_unreclaimable? no
lowmem_reserve[]: 0 0 0
Normal free:0kB min:0kB low:0kB high:0kB active:0kB inactive:0kB present:0kB pag
es_scanned:0 all_unreclaimable? no
HighMem free:0kB min:0kB low:0kB high:0kB active:0kB inactive:0kB present:0kB pa
ges_scanned:0 all_unreclaimable? no
DMA: 0*4kB 0*8kB 0*16kB 0*32kB 0*64kB 0*128kB 0*256kB 0*512kB 0*1024kB 0*2048kB
0*4096kB = 0kB
Normal: empty
HighMem: empty
oom-killer: gfp_mask=0xd2
DMA per-cpu:
cpu 0 hot: low 2, high 6, batch 1
cpu 0 cold: low 0, high 2, batch 1
Normal per-cpu: empty
HighMem per-cpu: empty[/b]
--- Quote End ---
thanks in advance!
0 项奖励
名誉分销商 II
1,218 次查看
There may be problem in initramfs image. rebuild it.
rm -rf ~/rootfs cp -a ~/buildroot/build_nios2/root ~/rootfs cd ~/rootfs# remove include and lib to save space# the dev nodes are generated via ~/download/rootfs_list rm -rf dev usr/include usr/lib# you may use this instead of the one from buildroot cp ~/download/inittab etc# clean headers for uClinux-dist cd ~/buildroot/build_nios2/staging_dir/include/linux rm config.h autoconf.h touch config.h autoconf.h cd ~/linux-2.6.x# rebuild image for initramfs make ARCH=nios2nommu CROSS_COMPILE=nios2-linux-uclibc-
0 项奖励
名誉分销商 II
1,218 次查看
The 8 MB sdram of DEII is very tight for uclinux.
remove unused applets in busybox, keep only init, msh, and some coreutils.
remove unused files in ~/rootfs/etc, keep only inittab
remove unused dev nodes in ~/download/rootfs_list, keep only console,zero,null.
cd ~/buildroot/build_nios2/busybox make menuconfig make cd ~/buildroot make rm -rf ~/rootfs cp -a ~/buildroot/build_nios2/root ~/rootfs cd ~/rootfs# remove include and lib to save space# the dev nodes are generated via ~/download/rootfs_list rm -rf dev usr/include usr/lib etc/*# you may use this instead of the one from buildroot cp ~/download/inittab etc# clean headers for uClinux-dist cd ~/buildroot/build_nios2/staging_dir/include/linux rm config.h autoconf.h touch config.h autoconf.h cd ~/linux-2.6.x# rebuild image for initramfs make ARCH=nios2nommu CROSS_COMPILE=nios2-linux-uclibc-
0 项奖励
名誉分销商 II
1,218 次查看
Thanks, hippo! Looks like its working now http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/laugh.gif
uClinux/Nios II Altera Nios II support (C) 2004 Microtronix Datacom Ltd. Built 1 zonelists Kernel command line: PID hash table entries: 64 (order: 6, 1024 bytes) Dentry cache hash table entries: 2048 (order: 1, 8192 bytes) Inode-cache hash table entries: 1024 (order: 0, 4096 bytes) Memory available: 6984k/8192k RAM, 0k/0k ROM (704k kernel code, 385k data) Mount-cache hash table entries: 512 (order: 0, 4096 bytes) Linux NoNET1.0 for Linux 2.6 Serial: JTAG UART driver $Revision: 1.4 $ ttyJ0 at MMIO 0x81004000 (irq = 1) is a jtag_uart io scheduler noop registered io scheduler deadline registered Freeing unused kernel memory: 304k freed (0xba000 - 0x105000) init started:  BusyBox v1.1.1-pre0 (2006.03.06-00:20+0000) multi-call binary BusyBox v1.1.1-pre0 (2006.03.06-00:20+0000) Built-in shell (msh) Enter &#39;help&#39; for a list of built-in commands. #
By the way, if I had to install the bluez module into the linux kernel as well as the driver for the IP core for USB, would that likely cause any problems with running out of RAM?
Also, in the toolchain, the compiler used to compile was
nios2-linux-uclibc-gcc hello.c -o hello -elf2flt
If I already have a compiled object file (compiled with g++), is there any way of converting the object file with something like elf2flt?
0 项奖励
名誉分销商 II
1,218 次查看
The kernel is working now.
--- Quote Start ---
By the way, if I had to install the bluez module into the linux kernel as well as the driver for the IP core for USB, would that likely cause any problems with running out of RAM?[/b]
--- Quote End ---
Add them one by one. It is still possible to run out of ram. Check in only what is required. Or if you could, change the sdram chip to a 16Mx16 device, check your PCB if extra MA lines are required.
--- Quote Start ---
If I already have a compiled object file (compiled with g++), is there any way of converting the object file with something like elf2flt?[/b]
--- Quote End ---
You can add the elf2flt flags. Note the libstdc++ might still have problems, it compiled and linked with elf2flt, but it crashed when running. I am not a c++ user, and I don&#39;t know how to resolve (and I am quite busy now).
0 项奖励
名誉分销商 II
1,218 次查看
when i nios2-download -g vmlinux!
it appears:
SOPC Builder]$ nios2-download -g vmlinux
ios2-elf-objcopy: &#39;./vmlinux&#39;: No such file
/vmlinux.srec: Unable to open input file
m: cannot remove `./vmlinux.srec&#39;: No such file or directory
/altera/kits/nios2_51/examples
why ?
where my &#39;vmlinux.bin&#39; file shoulde lay?
0 项奖励
名誉分销商 II
1,218 次查看
--- Quote Start ---
it appears:
sopc builder]$ nios2-download -g vmlinux
ios2-elf-objcopy: &#39;./vmlinux&#39;: no such file
/vmlinux.srec: unable to open input file
m: cannot remove `./vmlinux.srec&#39;: no such file or directory
why ?
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=14330)
--- quote end ---
--- Quote End ---
the vmlinux is in your kernel build dir .
and if you make zImage , arch/nios2nommu/boot/zImage .
Note the drives mapping in nios2 sdk shell,
drive c: is /cygdrive/c/
drive d: is /cygdrive/d/
if you map your linux home to h: on windows with samba server,
then it is /cygdrive/h/linux-2.6.x/vmlinux
or /cygdrive/h/linux-2.6.x/vmlinux/arch/nios2nommu/boot/zImage
0 项奖励
回复
