12747 Discussions
Problem running an application
Hi all,
I have built a hello world application with nios2 ide.
The application runs well if I copy the executable (hello.exe) and paste it onto a filesystem project (/bin) and upload the romfs.bin.
However, if I ftp the executable onto the target (/tmp), it does not run well.
I got the following error:
BINFMT_FLAT: reloc outside program 0x344000 (0 - 0x66fc/0x4140), killing hello.e
xe!
Does anyone know why??
Thanks in advance!
Kwok Wong
Please verify if you ftp your files in ascii or binary mode. it should be binary ?!?
I also have run into this problem, and aren't sure why. I have verified that I am transmitting in binary mode. I have just been recompiling the romfs each time to get around this.
--- Quote Start ---
originally posted by helmchen@Sep 5 2006, 10:33 AM
please verify if you ftp your files in ascii or binary mode. it should be binary ?!?
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=18081)
--- quote end ---
--- Quote End ---
You are right.
I thought I have tried using binary mode to transfer file.
Thank you.
