12748 Discussions
Problem to run the Hello example
I'm newbie, I'm trying to run the Hello World sample
I have a NiosII Evaluation Kit
The 'NIOS II IDE' is version 1.1.0
I have already sent the file
.../niosII_cyclone_1C12_eval/standard/standard_eval_board.sof
on the board using QuartusII Programmer V4.2
It was succesfull.
When I start the nios2-terminal, it works.
I'have build the example -> OK
I try to run it and I have the following error
Using cable "Nios II Evaluation Board [USB-0]", device 1, instance 0x00
Pausing target processor: OK
Reading System ID at address 0x021208B8: does not match
ID value does not match: read 0x14400B2E; expected 0x2FF81C2D
Timestamp value does not match: image on board is newer than expected
Read timestamp 13:10:34 1906/03/20; expected 9:45:02 2004/11/25
The software you are downloading may not run on the system which is currently
configured into the device. Please download the correct SOF or recompile.
Restarting target processor
What does it mean and what have I to do ?
Where can I find a good faq ?
Is it possible to perform a search on the forum ?
Thanks a lot
Best regards
hi,reproduce your project and make sure your selected the right ptf file,make sure the ptf file according to the downloaded hardware configure file (sof or pof).
Thank for these answer.
I'will check it asap.
I'll give you a feedback
