Problem when building project
I follow the steps of "Linux Quick Start Guide". But when I select "Build Project" after successfully configured the kernel,two errors occur after the building.
Error: expected comma after "nobreak"[/cygdrive/e/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_0.1.5/linux-2.6.x/arch/nios2nommu/kernel/entry.S] kernel_1s40 line 43
Error: expected comma after "break"[/cygdrive/e/altera/kits/nios2/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_0.1.5/linux-2.6.x/arch/nios2nommu/kernel/entry.S] kernel_1s40 line 897
How can I solve this?
Thanks a lot! http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/unsure.gif
Check out the following thread...
build error thread (http://www.niosforum.com/forum/index.php?act=st&f=18&t=1177&hl=expected+comma
Hope it helps
