Problem with CFI
hi
I follow the steps of this page http://nioswiki.jot.com/wikihome/operating...ms/compactflash (http://nioswiki.jot.com/wikihome/operatingsystems/compactflash
it can probe HD,but can't command it .
here is the message of screen.
uClinux/Nios II
Altera Nios II support © 2004 Microtronix Datacom Ltd.
setup_arch: No persistant network settings signature at 003F0000
Built 1 zonelists
Kernel command line:
PID hash table entries: 64 (order: 6, 1024 bytes)
Dentry cache hash table entries: 2048 (order: 1, 8192 bytes)
Inode-cache hash table entries: 1024 (order: 0, 4096 bytes)
Memory available: 6336k/8192k RAM, 0k/0k ROM (1282k kernel code, 478k data)
Mount-cache hash table entries: 512
NET: Registered protocol family 16
io scheduler noop registered
io scheduler deadline registered (default)
Serial: JTAG UART driver $Revision: 1.4 $
ttyJ0 at MMIO 0x80481130 (irq = 1) is a jtag_uart
dmfe_probe:eth0, 100000 Khz Nios
<DM9000> eth0 I/O: 80481138, VID: 90000a46
ADDR: 00:07:ed:00:00:00
dmfe_probe:eth1, 100000 Khz Nios
Uniform Multi-Platform E-IDE driver Revision: 7.00alpha2
ide: Assuming 50MHz system bus speed for PIO modes; override with idebus=xx
CF: ctl=1
hda: &#63733;, ATA DISK drive
arch/nios2nommu/kernel/irq.c(48): default irq handler vec=7 [0x7]
ide0 at 0x80481000-0x80481007,0x80481038 on irq 7
hda: max request size: 512KiB
hda: status error: status=0x58 { DriveReady SeekComplete DataRequest }
ide: failed opcode was: 0x27
hda: drive not ready for command
hda: 4278255360 sectors (2190466 MB) w/32640KiB Cache, CHS=65535/255/63
ide: failed opcode was: 0xef
hda: cache flushes supported
hda:hda: status error: status=0x58 { DriveReady SeekComplete DataRequest }
ide: failed opcode was: unknown
hda: set_geometry_intr: status=0x51 { DriveReady SeekComplete Error }
hda: set_geometry_intr: error=0x00 { }
hda: recal_intr: status=0x51 { DriveReady SeekComplete Error }
hda: recal_intr: error=0x00 { }
hda: task_in_intr: status=0x51 { DriveReady SeekComplete Error }
hda: task_in_intr: error=0x00 { }
is there any suggestion?
i just rebuild the kernel ,and it is working correctly.
http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/laugh.gif
