12748 Discussions
Problem with Flash Programmer
<div class='quotetop'>QUOTE </div>
--- Quote Start ---
#! /bin/sh# # This file was automatically generated by the Nios II IDE Flash Programmer.# # It will be overwritten when the flash programmer options change.#
cd E:/altera/qdesigns42/UP3_flash2/software/hello_world_0/Debug
# Creating .flash file for the project
$SOPC_KIT_NIOS2/bin/elf2flash --flash=U8 --base=0x00000000 --end=0x100000 --rese
t=0x0 --input=hello_world_0.elf --output=flash.flash --boot=$SOPC_KIT_NIOS2/comp
onents/altera_nios2/boot_loader_cfi.srec
WARNING: Default charset GBK not supported, using ISO-8859-1 instead
# Programming flash with the project
$SOPC_KIT_NIOS2/bin/nios2-flash-programmer --input=flash.flash --sof=e:/altera/U
P3_board/up3/system/up3.sof --base=0x00200000
Jun 27, 2005 10:55:31 AM - (??) nios2-flash-programmer: Launching Quartus Progra
mmer to download:
  e:/altera/UP3_board/up3/system/up3.sof
Pre-Reading 53KBytes of data from U8:
    ********************* (2.75 sec).
Erasing 4 Sectors:
    ********************* (1.719 sec).
Unable to send write-packet @0
buffer-chunk write failed @0
erase-block write failed @0
write failed @0
Jun 27, 2005 10:55:47 AM - (??) nios2-flash-programmer: Unable to write to flash
Jun 27, 2005 10:55:47 AM - (??) nios2-flash-programmer: Error: Write-operation f
ailed on device. - exiting.
WARNING: Default charset GBK not supported, using ISO-8859-1 instead[/b]
--- Quote End ---
When I port the NiosII Flash Programmer to my custom board, the problems above happens.
Can anybody help me to figner out the problems??
thanks!!
Hi wdzwdx,
On your custom board, is the flash base address still 0020_0000?
--Scott
I&#39;m sorry!! I can&#39;t make out what you exactly mean!
When I create my custom board, it set my flash base address to 0x0200000 automatically, and when I use my custom board, I set it to be 0x0000000. Is there any problem about the base address setting??
thanks!
Hi ,
Now I&#39;m confused, is the flash on your custom board located at 0000_0000 or 0020_0000?
--Scott
Hi,Scott
thanks!!
I have make it run.
Because I forget to connect the flash_byte_n to Vcc, it can&#39;t run correctly before.
--- Quote Start ---
Now I&#39;m confused, is the flash on your custom board located at 0000_0000 or 0020_0000?[/b]
--- Quote End ---
when programming to the flash, use the base address 0x000200000 of the custom board, and when run my project, it uses the base address 0x00000000.
--- Quote Start ---
P3_board/up3/system/up3.sof --base=0x00200000[/b]
--- Quote End ---
you can see that up3.sof is the .sof file of my custom board, and the aim to set up a custom board is programming the board.
