Problem with TCM
Hi everybody,
I begin descibing our system:
Quartus 5.01
NIOS II 5.01
64K TCM Instruction(Dual port memory--> 1 for I master and 1 for avalon data)
Base address --> 0x02300000
32K TCM Data
Base address --> 0x02310000
SDRAM Base adress --> 0x01000000
ext_ram Base adress --> 0x02000000
ext_flash Base address --> 0x00000000
SOPC Settings:
Reset address --> flash
Exception address --> Instruction TCM/s1, offset 20 --> address: 0x02300020
IDE settings:
.text --> Instruction TCM/s1
.rodata, .rwdata... --> DataTCM
The linker gives the next error:
section .text [02300020 -> 02305F83] overlaps section .exception [02300020 -> 0230001C7].
This error doesn't happen when both sections are located in SDRAM(this is the way we have it before using TCM).
So to me it seems that if the sections are in SDRAM the linker knows how to locate them in order not to overlap. But if I put the two sections in a TCM the linker can not locate them. Is this a bug??
What´s the problem? Thanks in advance,
Luis
