告知
12748 ディスカッション
Problem with getting IRQ from PIO (Really simple i guess)
名誉コントリビューター II
1,586件の閲覧回数
int context=0; volatile int edge_capture; int main() { IOWR_ALTERA_AVALON_PIO_IRQ_MASK(PIO_0_BASE,0xF); alt_irq_register(PIO_0_IRQ,(void*)&edge_capture, handle_pio); while(5); return 0; } static void handle_pio(void* context, alt_u32 id){ IOWR_ALTERA_AVALON_PIO_IRQ_MASK(PIO_0_BASE, 0); /* Cast context to edge_capture's type. It is important that this be * declared volatile to avoid unwanted compiler optimization. */ volatile int* edge_capture_ptr = (volatile int*) context; /* Store the value in the Button's edge capture register in *context. */ *edge_capture_ptr = IORD_ALTERA_AVALON_PIO_EDGE_CAP(PIO_0_BASE); IOWR_ALTERA_AVALON_PIO_EDGE_CAP(PIO_0_BASE,0); IOWR_ALTERA_AVALON_PIO_IRQ_MASK(PIO_0_BASE,0xF); } Why the interrupt never happens? It's a simple PIO (1bit)that i set to 1 in my verilog code (configured to generate a rising edge irq on my SOPC).. Thanks
0 件の賞賛
2 返答(返信)
名誉コントリビューター II
518件の閲覧回数
you not only need to enable interrupts on the PIO core, but on the NIOS side as well.
you can enable and disable interrupts using alt_irq_enable and alt_irq_disable.
try adding this after you register your ISR.
alt_irq_enable(PIO_0_IRQ);
名誉コントリビューター II
518件の閲覧回数
Thanks a lot!! It works
返信
