12745 Discussions
Problem with nano-X in a nios-mmu system
I'm working on using LCD in a nios2-mmu system on NEEK, I followed the instructions on nios-wiki to configure the kernel and modified altfb.c by advices of Kazu (The thread name is "Linux with MMU on Neek ",I can't give a direct link in my rank now,pls search the title in this forum), The result in my Linux is: "fb_test" command can be ran successfully:
The framebuffer device was opened successfully. 800*480, 32bpp The framebuffer device was mapped to memory successfully. but I can not run Nano-X :
cantnot bind to named socket and when I add microwindows app to the system, the following two commands were worked! I can see figures on my LCD Screen.
mtest mtest2 the image I download to NEEK is "linux.initramsfs.gz" in */nios2-linux/uClinux-dist/images.
What's the problem with nano-X? How can I start it?
I need your help, please give me some advice and thank you.
PS: I followed the thread of "Linux with MMU on NEEK", but there is not any response for almost four days. So, I post this thread, pls forgive me...
Because Kazu answered me the question, this session is not need being available any more, so, please administrator to close it. If you have the problem just as mine above, please refer to the session " Linux with MMU on NEEK". Thank you.
--Smarter.UJS
