12748 Discussions
Problem with writing uClinux image on flash
I followed the tutorial on http://www.alterawiki.com/wiki/flashprogrammer to write my zImage from the uClinux distribution on CFI-Flash but I can't upload the created file using 'nios2-flash-programmer'.
The error message is Empty flash content cannot be programmed or verifiedMy FPGA configuration is in EPCS-Flash and the steps for it seem to work but not for the program which should be in uploaded in CFI-Flash
I used the step 1. sof in epcs, program in cfi
Here is my command I type in:
elf2flash --base=0x02800000 --end=0x02FFFFFF --reset=0x0 --input=zImage --output=parallel_flash.flash --boot=$SOPC_KIT_NIOS2/components/altera_nios2/boot_loader_cfi.srecWhen I do 'cat parallel_flash.flash' there is only one row with a few numbers a characters. But the zImage is much bigger than that.
In attachment I have pictures of my reset_vector and the addresses of the flash types in sopc builder. Perhaps somebody see a mistake.
PS: The linefeed in the code section is just for better reading
Urmel
I think you may need to set a reset address in flash for elf2flash even if that's not what you're using for the processor.
Edit: I see you are using flash for the reset address in SOPC builder, so you need to give that absolute address to elf2flash.
Edit 2: Also, if you're using an MMU, you'll need to add 0xC0000000 to those addresses.
Hi Ykozlov,
thank you so much!
That reset address was the reason. I didn't realize that I mustn't use the offset but the base address + offset.
Urmel
