Now I'm designing a NIOS Kit with CS8900 chip. I use the CS8900 interface in the SOPC Builder directly, and I'm confuse with the byteenable[1..0] pin, 'cause there isn't any byteenale pins on the CS8900. Do I connect them to the AEN or SBHE pin on the chip, and how? btw, I connect the address signals 3..1 on nios to the address SA3 SA2 SA1 on the CS8900, It's that right? Thanks.Link Copied
Hello Simonhdl,
I am assuming that you have created CS8900 with its own bus in SOPC builder. If so then connect AEN to ground and connect byteenable[1] to SBHE. If you are using NIOS configured for 32bits then you would connect the address as follows; Nios Address CS8900 A2 A0 A3 A1 A4 A2 Good Luck!- Mark as New
Thanks, but I still confuse with the Address line.
In CS8900, it use A1,A2,A3 to access the registers, so does the Nios Address line connect like this : Nios CS8900 A2 -> A1 A3 -> A2 A4 -> A3 not the A0, A1,A2 in CS8900?? Thanks.
