Problems with Nios II
Hi all
I'm new in using nios II and I have some problems:
after generating system on SOPC Builder with:
- nios 2/f
- jtag uart
- pio (output, 1 bit)
- sysid
- onchip_memory
i open nios 2 SBT and select the template hello world. Now:
- if i build the pjt, the error is
"on chip memory overflowed by xxx bytes"
i solved it entering in the BSP editor , unchecking
- enable c++
- enable clean exit
- enable exit
and checking
- enable small c library
- enable reduced device drivers
than generate BSP. That's ok?
But if i add to hello world.c
# include "system.h"# include "altera_avalon_poi_regs.h" and the other code suggested in "my first nios II software design" to let blink a led,next to the 2 added include i have a question mark that says
"unresolved inclusion" and gives me error in building pjt ("undefined reference to main")
someone can help?
(the only code that i run without problems is hello world small...)
n.b: my hardware is altera DE2 board (cyclone 2), and my sw, quartus 2 10.1 and last version of nios2 SBT
The first problem seems due to the fact the initial code didn't fit into onchip_memory. Enabling small C lib and reduced drivers generates a code with smaller footprint. If you need the complete lib and drivers you may try to implement a bigger onchip mem, provided your device has it.
The second problem probably indicates that thelinker can't find the main() entry point. Does your project use main or alt_main?
Last remark: you wrote "altera_avalon_poi_regs.h"; is this a mistype or is really like this in your code? It should be altera_avalon_pio_regs.h
Thanks for your fast answer!
- to implement a bigger on chip memory i have to set a higher number of bytes or select a different one?
- my pjt use main() i have to change it?
- yes, "poi" is a mistype!
--- Quote Start ---
--- Quote End ---
Right. Set a bigger size in sopc builder, changing onchip mem properties.
Regarding the other issue, using main is correct.
Probably you have some something wrong in linker script.
I still use Quartus 9 and Nios IDE, so I can't help you much with Quartus 10 and Nios SBT
Please use DE2 SSRAM or SDRAM. Onchip RAM will not fit at all.
