Problems with pthreds
I'm a program benchmark with pthreads, but I'm having really problems with it. Now i'm only want to do a simple hello world, but when I execute it the uClinux reinit another time. Can someone help me please? Can put some example that really run? Thanks to all.
# include <stdio.h># include <unistd.h># include <stdlib.h># include <pthread.h># include <sched.h># include <errno.h>
void print_message_function( void ){
char message = "Hello";
printf("%s ", message);
pthread_exit(NULL);
void main (int argc, char *argv[]){
pthread_t thread1, thread2;
//char *message1 = "Hello";
//char *message2 = "World";
//pthread_attr_t pthread_attr_default;
printf("\nThread 1");
pthread_create( &thread1, NULL, (void*)&print_message_function, NULL);
printf("\nThread 2");
pthread_create( &thread2, NULL, (void*)&print_message_function, NULL);
pthread_exit(NULL);
exit(0);
Hi Guillemn,
Try these changes:
<div class='quotetop'>QUOTE </div>
--- Quote Start ---
/*void print_message_function( void ){*/
void print_message_function (void *arg){
pthread_exit(NULL);
/*pthread_exit(NULL);*/
/* Wait for threads to exit before trashing the pthread_t vars (on stack)*/
pthread_join (thread1, NULL);
pthread_join (thread2, NULL);
exit(0);
}[/b]
--- Quote End ---
--Scott
Hello, I compiled another time the file corrected, but the both files can be compiled perfectly, without warning and it can be put in uClinux. But when starts the both execution, the system renicialize every time.
Can it be a problem with a uClinux configuration? what I can do??
Guillem
can you post your Makefile for this program?
include Rules.mak
# # configurable options# - set DEBUG = 1 to turn on debugging support#
DEBUG = 0
PROJ_NAME = threads
INSTALL_DIR =
PROGS := $(PROJ_NAME).exe
CFLAGS +=
# # You should not need to modify anything beyond this point#
ifeq &#39;$(DEBUG)&#39; &#39;1&#39;
CFLAGS += -O0 -g
PROGS += $(PROGS:.exe=.gdb)
endif
all: $(PROGS)
threads.bin: threads.o
.PHONY: clean
clean:
-rm -f *.[oad] *.elf *.gdb *.bin *.exe
.PHONY: install
install: all
ifeq "$(INSTALL_DIR)" ""
$(error No installation directory specified)
endif
mkdir -p $(INSTALL_DIR)/bin
install -v $(filter %.exe, $(PROGS)) $(INSTALL_DIR)/bin
this is the Makefile, do you need the rules.mak too?
thanks for all,
Guillem
Add this to your Makefile, check and make sure -lpthread appears before -lc.
LDLIBS:=-lpthread $(LDLIBS)
