I have set up one NIOS2, one ONCHIP_RAM(4K), one INTERNAL_TIMER and four PIO in the SOPC builder. my board use 25Mhz osicllation.
I want to design a timer interrupt routine, just for glittering the LEDs. int main (void) __attribute__ ((weak, alias ("alt_main"))); alt_u8 x = 0x5; static void timer_interrupts(void* context, alt_u32 id) { IOWR_ALTERA_AVALON_TIMER_STATUS(SYS_TIMER_BASE, 0);//clear TO IOWR_ALTERA_AVALON_PIO_DATA(LED_PIO_BASE, x);//light LEDs if(x==5)x=0xA; else x=5; } int alt_main (void) { alt_irq_register(SYS_TIMER_IRQ, (void*)&x, timer_interrupts); IOWR_ALTERA_AVALON_TIMER_PERIODL(SYS_TIMER_BASE, 0xBC20); IOWR_ALTERA_AVALON_TIMER_PERIODH(SYS_TIMER_BASE, 0xBE); IOWR_ALTERA_AVALON_TIMER_CONTROL(SYS_TIMER_BASE, 7); while (1) { ; } return 0; } built complete!!! when I downlaod program to EP1c12, but the console said verify failed http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/sad.gif what's wrong with my routine??? the hardware is ok and i can download the hello_led routine.Link Copied
Is the RAM also connected to the data port of the processor?
Verified failed? Sounds to me like memory problem. Have you check the .elf size is it <4k? or as svhb pointed out: is the data and address ports connected to the CPU?
