Pthread_create hangs program
I'm trying to compile some C++ code that uses pthread on uClinux.
I'm using this toolchain:
http://www.nioswiki.com/index.php?title=OperatingSystems/UClinux/BinaryToolchain
I can compile C++ code just fine, but whenever I try to use pthreads, the program will hang at the pthread_create () call.
At this point I'm just trying to compile a very simple program. It will hange right at the create call and never exit.
In addition, I get a linker error when trying to use pthread_join.
# include <iostream># include <pthread.h># include <unistd.h> void *ReadMessagesThread(void *ptr); int main(int argc, char** argv) { using namespace std; pthread_t thread; cout << "starting pthread..." << endl; int rc = pthread_create(&thread, NULL, ReadMessagesThread, NULL); cout << "return value is : " << rc << endl; //pthread_join(thread, NULL); return 0; } void *ReadMessagesThread(void *ptr) { using namespace std; for (int i = 0; i < 5; i++) { cout << "In thread : " << i << endl; } } Here is the MakeFile I'm using:
PROJ_NAME = remoteModelServer CXX=nios2-linux-uclibc-g++ LDLIBS:=-lpthread $(LDLIBS) CFLAGS=-O2 -fno-gnu-keywords LDFLAGS=-Wl,-elf2flt $(PROJ_NAME): *.cpp $(CXX) $(LDLIBS) $(CFLAGS) $(LDFLAGS) -o $(PROJ_NAME).exe *.cpp .PHONY: clean clean: -rm -f *. *.elf *.gdb *.bin *.exe *.flt Any ideas what I could be doing wrong?
So I did a nios2-elf-objdump on the gdb file created and there is this line:
00000000 w *UND* 00000000 pthread_create
Which seems to imply that my program isn't properly finding the pthread library.
I tried to specify the path to libpthread.a by using the -L option in the MakeFile, but that did not work.
Any other ideas what could be wrong?
Hey Kag,
I'm experiencing the same problem. Have you found a way to fix it?
There seems to be with the linking process, I removed the -lpthread from the linker arguments and it doesn't complain about it.
Is there a way to check this? Why does the GPP automatically links the phtread lib? And why does the GCC not.
Would be great if you or someone else could help me.
I made some progress with the Problem, linking of the pthead-lib is not correctly done by G++. I managed to improve the situation describe by Hag by adding the path to the pthread.a to the linker command.
It looks like this:
nios2-linux-c++ -o ijpis -elf2flt="-s 65536" include/tinyxml.o include/tinyxmlparser.o include/tinyxmlerror.o include/tinystr.o opt/nios2/lib/libpthread.a
After that, it is able to link the invocation of pthread_join() and the objectdumb shows:
0001b170 g F .text 0000010c pthread_create
The situation is improved, but after starting the program it still hangs after pthread_create...
A note at the end: I use the gcc version 3.4.6. I haven't tried to use another, yet.
Best regards
