12748 Discussions
Qsys suddenly fails to generate HDL for my working code.
GordWait
Altera 14.1
NiosII Qsys system
Cyclone CVGT board
Windows 10
This has been working for years up until this week. Now QSYS is failing to build the HDL for my design.
I'm guessing a Windows 10 update broke something.  This was all working fine literally last week.
We have paid licenses for Quartus 14.1, and for DSP Builder and they have been working fine for us so no, I don't want to update the tools and pay for new stuff.
Yes, I am working on setting up Linux on a different PC to work around this issue.
In the meantime,
Here are the errors from Qsys:
Error: s0: Error during execution of "{C:/altera/14.1/quartus/../nios2eds/Nios II Command Shell.bat} make all 2>> stderr.txt": child process exited abnormally
Error: s0: Execution of command "{C:/altera/14.1/quartus/../nios2eds/Nios II Command Shell.bat} make all 2>> stderr.txt" failed
Error: s0: Authorized application C:\altera\14.1\quartus\bin64\jtagserver.exe is enabled in the firewall.
Error: s0: ]2;Altera Nios II EDS 14.1 [gcc4]C:/altera/14.1/quartus/bin64/uniphy_mcc -ac_code sequencer_mc/ac_rom.s -inst_code sequencer_mc/inst_rom.s -ac_rom ../qsys_core_uniphy_ddr3_s0_AC_ROM.hex -inst_rom ../qsys_core_uniphy_ddr3_s0_inst_ROM.hex -header sequencer/sequencer_auto.h -vheader ../sequencer_auto_h.sv -ac_rom_init sequencer/sequencer_auto_ac_init.c -inst_rom_init sequencer/sequencer_auto_inst_init.c -DAC_ROM_USER_ADD_0=0_0000_0000_0000 -DAC_ROM_USER_ADD_1=0_0000_0000_1000 -DAC_ROM_MR0=0001000100001 -DAC_ROM_MR0_CALIB= -DAC_ROM_MR0_DLL_RESET=0001100100000 -DAC_ROM_MR1=0000000000110 -DAC_ROM_MR1_OCD_ENABLE= -DAC_ROM_MR2=0000000000000 -DAC_ROM_MR3=0000000000000 -DAC_ROM_MR0_MIRR=0001001000001 -DAC_ROM_MR0_DLL_RESET_MIRR=0001011000000 -DAC_ROM_MR1_MIRR=0000000000110 -DAC_ROM_MR2_MIRR=0000000000000 -DAC_ROM_MR3_MIRR=0000000000000 -DQUARTER_RATE=0 -DHALF_RATE=1 -DFULL_RATE=0 -DNON_DES_CAL=0 -DAP_MODE=0 -DGUARANTEED_READ_BRINGUP_TEST=0 -DMEM_ADDR_WIDTH=13 -DHARD_PHY=0
Error: s0: UniPHY Sequencer Microcode Compiler
Error: s0: Copyright (C) 1991-2010 Altera Corporation
Error: s0: Info: Reading sequencer_mc/ac_rom.s ...
Error: s0: Info: Reading sequencer_mc/inst_rom.s ...
Error: s0: Info: Writing ../qsys_core_uniphy_ddr3_s0_AC_ROM.hex ...
Error: s0: Info: Writing ../qsys_core_uniphy_ddr3_s0_inst_ROM.hex ...
Error: s0: Info: Writing sequencer/sequencer_auto_ac_init.c ...
Error: s0: Info: Writing sequencer/sequencer_auto_inst_init.c ...
Error: s0: Info: Writing sequencer/sequencer_auto.h ...
Error: s0: Info: Writing ../sequencer_auto_h.sv ...
Error: s0: Info: Microcode compilation successful
Error: s0: C:/altera/14.1/quartus/../nios2eds/sdk2/bin/nios2-bsp hal sequencer_bsp .. --default_sections_mapping sequencer_mem --use_bootloader DONT_CHANGE
Error: s0: child process exited abnormally
Error: s0: Cannot find sequencer/sequencer.elf
Error: s0: An error occurred
while executing
"error "An error occurred""
(procedure "_error" line
invoked from within
"_error "Cannot find $seq_file""
("if" then script line 2)
invoked from within
"if {[file exists $seq_file] == 0} {
(procedure "alt_mem_if::util::seq_mem_size::get_max_memory_usage" line 14)
invoked from within
"alt_mem_if::util::seq_mem_size::get_max_memory_usage [file join "sequencer" "sequencer.elf""
invoked from within
"set calc_mem_size [alt_mem_if::util::seq_mem_size::get_max_memory_usage [file join "sequencer" "sequencer.elf"]]"
invoked from within
"if { !$do_only_rw_mgr_mc && !($bfm_mode || $hps_mode)} {
set calc_mem_size [alt_mem_if::util::seq_mem_size::get_max_memory_usage [file join "sequenc..."
(procedure "generate_qsys_sequencer_sw" line 877)
invoked from within
"generate_qsys_sequencer_sw $prepend_str $protocol $pre_compile_dir $fileset $inhdl_dir $rdimm $lrdimm 0 0 $nios_hex_file_name $ac_rom_init_file_name ..."
invoked from within
"set seq_mem_size_list [generate_qsys_sequencer_sw $prepend_str $protocol $pre_compile_dir $fileset $inhdl_dir $rdimm $lrdimm 0 0 $nios_hex_file_name ..."
("if" else script line 2)
invoked from within
"if {[::alt_mem_if::util::qini::qini_value alt_mem_if_seq_size_request 0] > 0} {
set seq_mem_size [::alt_mem_if::util::qini::qini_value alt_mem_if_se..."
(procedure "alt_mem_if::gen::uniphy_gen::generate_qsys_sequencer" line 212)
invoked from within
"alt_mem_if::gen::uniphy_gen::generate_qsys_sequencer "${name}" $protocol $tmpdir $fileset {}"
invoked from within
"set qsys_sequencer_files_list [alt_mem_if::gen::uniphy_gen::generate_qsys_sequencer "${name}" $protocol $tmpdir $fileset {}]"
(procedure "alt_mem_if::gen::uniphy_gen::generate_sequencer_files" line 3)
invoked from within
"alt_mem_if::gen::uniphy_gen::generate_sequencer_files $name "DDR3" $tmpdir QUARTUS_SYNTH"
invoked from within
"foreach generated_file [alt_mem_if::gen::uniphy_gen::generate_sequencer_files $name "DDR3" $tmpdir QUARTUS_SYNTH] {
set file_name [file tail $genera..."
(procedure "generate_synth" line
invoked from within
"generate_synth qsys_core_uniphy_ddr3_s0"
Info: s0: "uniphy_ddr3" instantiated altera_mem_if_ddr3_qseq "s0"
Error: Generation stopped, 1069 or more modules remaining
Info: qsys_core: Done "qsys_core" with 286 modules, 237 files
Error: ip-generate failed with exit code 1: 21 Errors, 19 Warnings
Info: Finished: Create HDL design files for synthesis
RichardTanSY_Altera
Could you check if the Window update might have accidentally mess up the WSL (Windows Subsystem for Linux) feature?
For older Quartus version 14.1, you will need to turn OFF the WSL as stated in the KDB below.
Link: https://www.intel.com/content/www/us/en/support/programmable/articles/000080619.html
p.s. For Quartus version > Std19.1/Pro19.2, Nios II currently does not support WSL2, as mentioned here.
To check which version of WSL you are running currently:
  1. Open a command prompt as administrator and type wsl --list –verbose. You should get something like the following:
PS C:\Users\xxx> wsl --list --verbose
NAME   STATE     VERSION
* Ubuntu  Stopped    1
Richard Tan
RichardTanSY_Altera
We noticed that we haven't received a response from you regarding the latest previous question/reply/answer, and will now transitioning your inquiry to our community support.
We apologize for any inconvenience this may cause and we appreciate your understanding.
If you have any further questions or concerns, please don't hesitate to reach out. Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support.
The community users will be able to help you on your follow-up questions.
Thank you for reaching out to us!
Richard Tan
