12747 Discussions
Question about flash-programmer
hi!
when i use flashprogrammer download my process to epcs64.it always failure.the info in console window is:
# ! /bin/sh# # This file was automatically generated by the Nios II IDE Flash Programmer.# # It will be overwritten when the flash programmer options change.#
cd D:/altera/kits/nios2/examples/myprocess/flashprogram/software/memtest_0/Debug
# Creating .flash file for the FPGA configuration
$SOPC_KIT_NIOS2/bin/sof2flash --flash=U59 --offset=0x00000000 --epcs --input=$SO
PC_KIT_NIOS2/examples/myprocess/flashprogram/flashprogram.sof --output=flashprog
ram.flash
Info: *******************************************************************
Info: Running Quartus II Convert_programming_file
Info: Command: quartus_cpf --no_banner --convert --device=EPCS64 --option=flashp
rogram.opt d:/altera/kits/nios2/examples/myprocess/flashprogram/flashprogram.sof
flashprogram.pof
Info: Quartus II Convert_programming_file was successful. 0 errors, 0 warnings
Info: Processing ended: Mon Apr 03 15:56:57 2006
Info: Elapsed time: 00:00:03
Info: Command: quartus_cpf --no_banner --convert flashprogram.pof flashprogram.r
pd
Info: Processing ended: Mon Apr 03 15:57:01 2006
Info: Elapsed time: 00:00:04
WARNING: Default charset GBK not supported, using ISO-8859-1 instead
# Programming flash with the FPGA configuration
$SOPC_KIT_NIOS2/bin/nios2-flash-programmer --input=flashprogram.flash --sof=$SOP
C_KIT_NIOS2/examples/myprocess/flashprogram/my_program/system/my_program.sof --e
pcs
Apr 3, 2006 3:57:02 PM - (??) nios2-flash-programmer: Launching Quartus Programm
er to download:
d:/altera/kits/nios2/examples/myprocess/flashprogram/my_program/system/my_p
rogram.sof
Error: Can't configure device. Expected JTAG ID code 0x020B40DD for device 1, bu
t found JTAG ID code 0x020B30DD.
Error: Operation failed
Error: Quartus II Programmer was unsuccessful. 2 errors, 0 warnings
Apr 3, 2006 3:57:05 PM - (??) nios2-flash-programmer: Unable to download SOF: d:
/altera/kits/nios2/examples/myprocess/flashprogram/my_program/system/my_program.
sof, exiting
# Creating .flash file for the project
$SOPC_KIT_NIOS2/bin/elf2flash --flash=U59 --epcs --base=0x0 --end=0x7fffffff --i
nput=memtest_0.elf --output=epcs_controller.flash --boot=$SOPC_KIT_NIOS2/compone
nts/altera_nios2/boot_loader_epcs.srec
# Programming flash with the project
$SOPC_KIT_NIOS2/bin/nios2-flash-programmer --input=epcs_controller.flash --sof=_
_NO_SOF_PLEASE__ --epcs
Apr 3, 2006 3:57:05 PM - (??) nios2-flash-programmer: SOF-download skipped.
Send (32) failed.
Unable to synchronize with target.
Apr 3, 2006 3:57:25 PM - (??) nios2-flash-programmer: Error opening target hardw
are
In order to program flash, you must first create a purpose-built
flash-programming design (i.e. FPGA configuration) and associate it with
your particular board. The Nios development kit is delivered with purpose-bui
lt
flash-programming designs pre-built for several development boards. If you wi
sh
to program flash on your own board, you must first create a flash-programming
design.
The process of creating a flash-programming design for your board is mostly
automated. From a bash-shell, execute this script:
mk_target_board --help
The help-message includes references to other documentation on programming
flash and targeting Nios systems to custom board designs.
- exiting.
$SOPC_KIT_NIOS2/bin/elf2flash --flash=U5 --base=0x00000000 --end=0x7fffff --rese
t=0x801800 --input=memtest_0.elf --output=ext_flash.flash --boot=$SOPC_KIT_NIOS2
/components/altera_nios2/boot_loader_cfi.srec
$SOPC_KIT_NIOS2/bin/nios2-flash-programmer --input=ext_flash.flash --sof=__NO_SO
F_PLEASE__ --base=0x00800000
Apr 3, 2006 3:57:25 PM - (??) nios2-flash-programmer: Input file empty--no data
to program into flash. Exiting.
/////what's the reason? thankyou!/////
hi! i have made some changes but it still can't dwonload to my epcs16.this is the info. thank you very much!!!!!!!
ram.flash
flashprogram.pof
Info: Processing ended: Tue Apr 04 09:14:51 2006
pd
Info: Processing ended: Tue Apr 04 09:14:55 2006
C_KIT_NIOS2/examples/myprocess/flashprogram/ceshif/system/ceshif.sof --epcs
Apr 4, 2006 9:14:57 AM - (??) nios2-flash-programmer: Launching Quartus Programm
er to download:
d:/altera/kits/nios2/examples/myprocess/flashprogram/ceshif/system/ceshif.s
of
Apr 4, 2006 9:15:04 AM - (??) nios2-flash-programmer: Error copying data to the
flash target
Read failed @00000000
Apr 4, 2006 9:15:05 AM - (??) nios2-flash-programmer: SOF-download skipped.
Apr 4, 2006 9:15:10 AM - (??) nios2-flash-programmer: Error copying data to the
flash target
Apr 4, 2006 9:15:11 AM - (??) nios2-flash-programmer: Input file empty--no data
