12748 Discussions
Read BMPfiles in CF and output it
Hello.
I want to make a small system with nios2 development kit(Stratix2 EP2S60ES).
All that I want to do is,
*Read BMP file in CF (FAT16 format).
*Output the BMP file data to custom logic block in Quaruts2 design.
*The custom logic output the data to PROT2 connector.
I read the forum, and I found several ways
(uCLinux, eCos, Altera Host Based File System, Making own filesystem etc).
But I can't judge which is the easiest way.
Which is the easiest way to make this?
And could you explain the detail of the easiest way ?
(For me, it is the first time to use nios2.
I'm harware engineer. I don't know about software design, well.
So, I want to know every step to make it.)
Thank you.
Best regards.
I'd go with uClinux on this. Download uClinux and work through the tutorial. Then modify the "full-featured" demo design for your board to hook up the CF slot (disconnect the LCD). Then it's just a matter of writing a Linux program to read from CF and write to your peripheral.
