12748 Discussions
Read/Write EPCS64 flash from Nios II
Hi all,
Actually, I'm trying to write/read my flash device using the HAL functions.
After opening the device, I write into the EPCS64 using alt_write_flash_block, then i read it using alt_read_flash.
The problem i have is that the data read/ written showen in the Nios II console are not the same.
The code for writing and reading is below:
int Write_flash( alt_flash_fd* fd, float *Ks_para,int test_offset) { int i; int ret_code = 0; alt_u8 *ptr_ks=(alt_u8*) Ks_para; int test_length = sizeof(Ks_para); // before writing in a sector, we should erase it before ret_code=alt_epcq_controller_erase_block(fd, test_offset); if(!ret_code){ for(i=0;i<test_length;i++){ printf( "data_written= 0x%08x\n\r",i,ptr_ks); } ret_code=alt_write_flash_block(fd,test_offset,test_offset,ptr_ks,test_length); } if (ret_code) { printf( "\nERROR: function alt_write_flash failed. ret_code %d\n",ret_code); return ret_code; } return ret_code; }
float Read_flash( alt_flash_fd* fd,int test_offset) { int test_length = 4; alt_u8 data_read; int i=0; union conv2float read_flash; float Ks_para=0.0; int ret_code = 0; if (!ret_code) { ret_code=alt_read_flash(fd, test_offset, data_read, test_length); if(!ret_code) { for(i=0;i<4;i++){ read_flash.V_In=data_read; printf( "Flash+%d= 0x%08x\n\r",i,read_flash.V_In); } Ks_para=read_flash.V_Fl; } } if (ret_code) { printf( "\nERROR: function READ failed. ret_code %d\n",ret_code); } return Ks_para; }
Do you have an idea why ?
Thank you in advance.
Best regards
I want just to precise that in debug mode, I can see that the location where I write changed but with wrong values.
For example, I'm writing 0x40228f5c to 04FC0000 address, but I can see this :
04FC0000 2E479120 FFFFFFFF FFFFFFFF FFFFFFFF
I don't find an explication why.
Do you have any suggestion please?
Best regards
