12745 Discussions
Redirect the connection to the local website
Hi everyone,
I am using NIOS 1c12 evaluation kit , NIOS IDE 5.0 , Microtronix Linux Extensions Version 1.4
After I "ifconfig" the target in uClinux , I can access the local website via a web browser. By default , when I browse the site , the target will take me to "/home/httpd" to read files (*.html , *.bmp , *.jpg , ...) there.
What should I do to change the default path (ie /var) instead of "/home/httpd" ???
Quan
<div class='quotetop'>QUOTE </div>
--- Quote Start ---
What should I do to change the default path (ie /var) instead of "/home/httpd" ???[/b]
--- Quote End ---
Take a look at the /etc/config/boa.conf file at the line "#DocumentRoot /var/www"
Warm Regards
