Request_Region
I'm trying to write an interrupt driver. I have seen that many drivers inside init_function appeared a function like "request_reg_region". I have read some documentation about the function but I haven't clear my ideas. I don't understand the necessity of doing this manner, because inside uClinux there is the document "nios.h" where appear all my physical adress which I can access my hardware.
If someone can explain me which are benefits.
Thanks a lot.
You should never directly access hardware registers. The new NIOS Linux distribution is able to use the MMU and thus any (driver-) software should be done in a portable way.
-Michael
OK I understand thanks for the answer.
