Reset
Hello!
I have next problem: I wrote simple program with timer interrupt handler. In *.vwf file at reset line I set two reset signals. After the first reset signal my program simulation is ok- timer interrupt handler works. After the second reset this function doesn't work.
May be I have to set options in project properties in NIOS II IDE ?
Thank you.
