12747 Discussions
Riscfree compilation error with message ".bss not within region onchip_mem"
Thierry29
I'm working on a DE10 Lite board project integrating a NiosV/m microprocessor. The development tools are Quartus Prime Lite v23.1.1. The hardware has been correctly generated and also the BSP. The software application is a simple "hello world" program hello.c.
My problem concerns compilation with RiscFree. The compilation aborts at the link stage with the message "address 0x4022284 of hello.elf section '.bss' is not within region 'onchip_mem'".
In the hardware system an on-chip memory is used as unique memory for data and the program with addresses between 0x400_0000 and 0x402_7fff.
Furthermore I noticed that the compilation process corresponds to a gmake command that RiscFree found in a Matlab directory (Matlab is installed on my PC). I tried to find the same gmake program in the Quartus suite installation directory, but it does not exist (so it is not planned that riscfree will use it?).
I do not know if these two problems are related. Here are some screenshots to help you understand.
A part of the hardware system designed with Platform Designer, mainly NiosV/m and on-chip memoryA part of the hardware system designed with Platform Designer, mainly NiosV/m and on-chip memoryAddress mappingAddress mappingBSP editor: Drivers viewBSP editor: Drivers viewCompilation aborts: gmake.exe is mentionned at the last lineCompilation aborts: gmake.exe is mentionned at the last lineCompilation aborts: message indicating that .bss is not within region 'onchip_mem'Compilation aborts: message indicating that .bss is not within region 'onchip_mem'
Thank you very much in advance for your help
Thierry
RolandoS_Altera
Hello Thierry
I am new on the Nios V area, but will try to help you on this asking to some of the experts on this.
From the captures that you show, the settings that you have for the starting point of the .bss looks correct as this is inside of the On-chip memory.
Now, do you know if the size of the  .bss section is defined somewhere? I am trying to determine if this fully fits in the On-chip memory.
Also, not sure if there is a link script available (a file with .ld or .icf extension). If this exist, here we also need to check that the .bss fits in On-chip memory.
For the issue related to using gmake from Matlab, it is possible that in the Path environment variable the Matlab path is being used before that  the path of Quartus which means that it has higher precedence than the one for Quartus. You can try to modify this variable to include the path of Quartus before than the path of Matlab.
Rolando
Thierry29
Hi Rolando,
thanks for your help.
Regarding the .bss section, I have no idea of the needed size. I am attaching an archive file of my software directory (after performing a build clean). You might find some interesting informations inside. For completeness I join also the .sopcinfo file (in DE10_LITE_Qsys.zip file) from which the bsp (hal_bsp) was generated.
Regarding the gmake issue, I already have placed the Matlab path at the end of the PATH variable, but the behavior remains unchanged. I do not see a gmake.exe file in the Quartus installation tree directories. So, even though the Quartus variable takes precedence, no program is found. I deleted the gmake.exe file from Matlab directory. Riscfree throws an error saying that gmake is no longer available.
Thierry
RolandoS_Altera
Hi  Thierry
I exercised the tutorial at the following application note: https://cdrdv2-public.intel.com/784469/an-784468-784469.pdf
At the section 1.2.2.4 there is an alternative to build the application .elf file from the command line instead for riscfree:
$cmake -G "Unix Makefiles" -DCMAKE_BUILD_TYPE=Debug -B software/app/debug -S
software/app
$ make -C software/app/debug
Have you tried this? You need to do it after entering into the niosv shell.  I was told that everything that you need is already included as part of the Quartus installation, so no gmake from other application will be needed. I just tried with the software directory that you provided using Quartus Pro 25.1 and was able to generate the .elf (attaching this one compressed).
So, I am guessing that the issue that you are seeing is from actually being using the gmake from Matlab.
Rolando
Thierry29
Hi Rolando,
I have attached the app and bsp directories that I generated (located in the "soft2" directory) so you can verify their accuracy. The next step is to import the project into Riscfree. The version of Riscfree I am using (v23.4.1, 3rd Nov 2023 installed with Quartus 23.1.1) does not implement the "Import Nios V CMake Project" option that is used in the application note 985.
Could you please tell me exactly how to import the project with this version of Riscfree?
Thierry
RolandoS_Altera
I have tried with the Rsicfree version that you indicated but seems that this version doesn't support the direct import of the NiosV Cmake project.  I will need to ask if there is a way to do it from Riscfree, but my guess is that you will need to build the application from the NiosV shell.
Thierry29
Hi Rolando,
an unofficial tutorial explains how to import a Nios V project into Riscfree for versions that do not yet offer the automatic import option (https://malt.zendesk.com/hc/en-us/articles/9280647796761-Nios-V-Project-Development-Procedure-Using-Ashling-RiscFree-IDE , part 4.5.1). I was not able to follow this procedure, it may not exactly match the version I am using.
I would use the last version of Riscfree but it seems it has a bug : https://community.intel.com/t5/Nios-V-II-Embedded-Design-Suite/RiscFree-v25-1-1-no-longer-finds-BSP-and-compiler-headers-files/m-p/1676846#M53545 without a clear workaround.
Thierry
RolandoS_Altera
Hi Thierry
I was able to build your application from Riscfree using the instructions provided in the Macnica application note. I also looked in to the case that reports the issue in Riscfree and I agree that the workaround is not clear. I am asking internally to see if the person who was supporting that case is able to provide the workaround.
Rolando
Thierry29
Hi Rolando,
it is good news that you were able to build the application using the Macnica application note. I tried to do the same thing and can detail where our paths seem to diverge.
I follow very scrupulously the tutorial up to the end of 4.5.1. The only difference is that I am using Riscfree v23.4.1 instead of v22.2.2. Everything seems normal until the "Finish" command to create the project in Risfree. Warnings are displayed in "Problems" tab with the informations below (by category):
Description:
File '/app/build/Debug/compile_commands.json' was not created in the build. Your workbench will not know all include paths and preprocessor defines.
Resource:
app
de.marw.cmake.cdt.language.settings.providers.CompileCommandsJsonParser
Type:
CMAKE_EXPORT_COMPILE_COMMANDS Parser Problem
Despite these warnings, I tried to build the application ("Build Project" command). As you can see below, the project is build (with no errors) with gmake not cmake. I do not understand why.
08:58:03 **** Build of configuration Debug for project app ****
"C:\\PROGRA~1\\MATLAB\\R2020b\\bin\\win64\\gmake.exe" -j all
[ 1%] Building ASM object bsp/CMakeFiles/hal2_bsp.dir/HAL/src/alt_log_macro.S.obj
[ 3%] Building ASM object bsp/CMakeFiles/hal2_bsp.dir/HAL/src/machine_trap.S.obj
[ 96%] Building C object CMakeFiles/hello.elf.dir/hello.c.obj
[ 97%] Linking C executable hello.elf
[ 97%] Built target hello.elf
[100%] Creating hello.elf.objdump.
[100%] Reporting memory available for stack + heap in hello.elf.
hello.elf
* 125.44 KB - Program size (code + initialized data).
* 23.36 KB - Free for stack + heap.
[100%] Built target niosv-stack-report
[100%] Built target create-objdump
08:58:10 Build Finished. 0 errors, 0 warnings. (took 7s.9ms)
I join the app and bsp. You might want to check if the behavior is the same in your case.
Thank,
Thierry
RolandoS_Altera
Hi Thierry
I built this in RiscFree installed in Linux (same version as yours) and I see that it also uses gmake. The version of gmake that uses seems to be the version that is installed in the machine /usr/bin/gmake:
12:14:32 **** Clean-only build of configuration Debug for project app ****
/usr/bin/gmake -j clean
/bin/sh: /home/rolando/intelFPGA_pro/23.4b79/niosv/bin/../../quartus/linux64/libtinfo.so.6: no version information available (required by /bin/sh)
12:14:32 Build Finished. 0 errors, 0 warnings. (took 115ms)
12:14:32 **** Build of configuration Debug for project app ****
/usr/bin/gmake -j all
[ 1%] Building ASM object bsp/CMakeFiles/hal2_bsp.dir/HAL/src/alt_mcount.S.obj
[ 2%] Building ASM object bsp/CMakeFiles/hal2_bsp.dir/HAL/src/alt_log_macro.S.obj
[ 3%] Building ASM object bsp/CMakeFiles/hal2_bsp.dir/HAL/src/crt0.S.obj
[ 98%] Creating hello.elf.objdump.
sh: /home/rolando/intelFPGA_pro/23.4b79/niosv/bin/../../quartus/linux64/libtinfo.so.6: no version information available (required by sh)
/bin/bash: /home/rolando/intelFPGA_pro/23.4b79/niosv/bin/../../quartus/linux64/libtinfo.so.6: no version information available (required by /bin/bash)
hello.elf
* 124.45 KB - Program size (code + initialized data).
* 24.35 KB - Free for stack + heap.
12:14:32 Build Finished. 0 errors, 0 warnings. (took 361ms)
When building manually, seems that it does it 2 stages:
* cmake: creates all the components needed to build through gmake
* gmake: builds the binaries
So I think that the gmake stage that you see is expected. What I am not sure about is why it uses gmake for Matlab. Perhaps in Windows, that's the gmake that it finds and then it uses that.
Rolando
Thierry29
Hi Rolando,
thank you for your time.
From your last post I understand that using gmake is normal with this version of Riscfree. My problem is that gmake exists only in the Matlab directory on my PC. I checked this point. There is no other gmake.exe files anywhere else on my hard drive. My os is Windows so this program would be normally installed in the riscfree directory (instead of /usr/bin/ for Linux). Could you please check point? I would like to make sure that the installation of riscfree is not corrupted.
Thierry
RolandoS_Altera
Hi Thierry
Sorry, it took some time to get Quartus 24.3.1 installed in Windows. I did some testing in Windows
Test 1: If I tried to build the project from Riscfree when I opened this just by doing a double-click on the Riscfree.exe file, the build fails, reporting this:
Regardless of this, I see that the hello.elf file is created.
Test2:  If I opened RiscFree from a CMD window in which I initialized the Nios V Shell ( C:\intelFPGA_pro\23.4\riscfree\RiscFree\Riscfree.exe), I was able to build the project successfully.
In both cases,  I don't see the progress capture in the Console in which you observe the gmake command. The only text that I saw in these 2 tests is the following:
20:41:07 Buildscript generation: app::Debug in C:\NiosVRiscFree_Test\soft2\app\build\Debug
cmake -DCMAKE_BUILD_TYPE:STRING=Debug -DCMAKE_EXPORT_COMPILE_COMMANDS:BOOL=ON -G "Unix Makefiles" "C:\\NiosVRiscFree_Test\\soft2\\app"
-- The ASM compiler identification is GNU
-- Found assembler: C:/intelFPGA_pro/23.4/riscfree/toolchain/riscv32-unknown-elf/bin/riscv32-unknown-elf-gcc.exe
-- The C compiler identification is GNU 12.1.0
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Check for working C compiler: C:/intelFPGA_pro/23.4/riscfree/toolchain/riscv32-unknown-elf/bin/riscv32-unknown-elf-gcc.exe - skipped
-- Detecting C compile features
-- Detecting C compile features - done
-- The CXX compiler identification is GNU 12.1.0
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Check for working CXX compiler: C:/intelFPGA_pro/23.4/riscfree/toolchain/riscv32-unknown-elf/bin/riscv32-unknown-elf-c++.exe - skipped
-- Detecting CXX compile features
-- Detecting CXX compile features - done
-- Configuring done (9.4s)
-- Generating done (0.1s)
-- Build files have been written to: C:/NiosVRiscFree_Test/soft2/app/build/Debug
20:41:17 Buildscript generation finished (took 9939 ms)
I did some additional test to see if in any of them I could see the progress capture to try to see if I can see what gmake uses. From several attemps I was able to do it:
1) In a CMD window enter into the niosv shell: C:\intelFPGA_pro\23.4\niosv\bin\niosv-shell.exe
2) In this CMD window, run the cmake command: cmake -G "Unix Makefiles" -DCMAKE_BUILD_TYPE=Debug -B soft2/app/debug -S soft2/app
3) Open RiscFree by double-clicking on the .exe file (not under the niosV shell) and create the C/C++ Cmake project as indicated in the Macnica application note.
4) In Riscfree, build the project. In this case, I see that this fails with the error seen in Test1 above. Close RiscFree.
5) In this CMD window in which the niosv shell is running, open RiscFree using the same workspace used when the project was created.
6) Build this project again. This time the build succeds and now it shows the progress capture as shown next:
17:55:33 **** Incremental Build of configuration Debug for project app ****
"C:\\intelFPGA_pro\\23.4\\riscfree\\build_tools\\bin\\make.exe" -j all
[ 3%] Building ASM object bsp/CMakeFiles/hal2_bsp.dir/HAL/src/alt_mcount.S.obj
[ 4%] Building ASM object bsp/CMakeFiles/hal2_bsp.dir/HAL/src/machine_trap.S.obj
hello.elf
* 124.44 KB - Program size (code + initialized data).
* 24.36 KB - Free for stack + heap.
 Here I can see that it uses the make.exe that is included as part of the RiscFree installation at C:\intelFPGA_pro\23.4\riscfree\build_tools\\bin\\make.exe
Repeating this in Linux, I see that it uses /usr/bin/gmake. I am guessing that perhaps it tries to find gmake and in case it doesn't exist it goes to find make. In Windows I don't have gmake so, perhaps it uses the make included in Riscfree.
I think that you can try to remove the Matlab path from the Windows corresponding $PATH environment and see if this time it uses the make from the RiscFree installation.
Hope these experiments could be helpful.
Rolando
Thierry29
Hi Rolando,
yes, you're right. When the path to Matlab is removed, I can compile with make instead of gmake.
I wonder if compiling with gmake is problematic since it is used in Linux systems? This is to avoid having to manage environment variables every time I need Risfree or Matlab.
One last question: are you getting the same warnings "File '/app/build/Debug/compile_commands.json' was not created in the build. Your workbench will not know all include paths and preprocessor defines." (my post 07-08-2025)?
Thank you for your help and thorough testing.
Thierry
RolandoS_Altera
Hi Thierry
Yes, I also see these warnings after I create the project with Riscfree:
Let me ask around about the issue of using gmake vs make. Not really sure if it's true that it tries by default using gmake instead of make.
Rolando
BoonBengT_Altera
Hi @Thierry29,
Greetings, just checking in to see if there is any further doubts in regards to this matter.
Hope your doubts have been clarified.
Best Wishes
BB
BoonBengT_Altera
Hi @Thierry29,
Greetings, as we do not receive any further clarification/updates on the matter, hence would assume challenge are overcome.
Please login to ‘ https://supporttickets.intel.com/s/?language=en_US’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions. For new queries, please feel free to open a new thread and we will be right with you. Pleasure having you here.
Best Wishes
BB
