12745 Discussions
Run NiosII program in command line + hostfs
I'm running a program in NiosII that read and write files in my host PC. For that I'm using the NIOSII IDE.
As I have to repeat this running several times, i'd like to make this run full automatic so I don't need to enter in the graphical mode every time.
For that i'm having a problem in trying to run niosII program because using the command line, i'm not being able to mount the hostFS. Does anybody know how can I do that?
So far, my script to program FPGA + run NIOSII project has the following steps:
1- Program FPGA
>> quartus_pgm -c "<usb-blaster name>" <file.cdf>
2- Build nios project:
>> nios2-build-project --projectName=<projectName>
3- Configure Nios
>> nios2-configure-sof <sof_file.sof> && nios2-download -g <file.elf>
4.1- Open Nios terminal to check output of running program (in one linux terminal)
>> nios2-terminal
4.2- Run program in Debug mode (required for hostFS to work) -- in another linux terminal
>> nios2-debug <file.elf>
Once again, following this steps I cannot access the file to read and write because I think hostFS is not mounted on /mnt/host
Using IDE the program works fine.
I'm using quartus + Nios2-IDE version 10.1
regards,
