- Als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- RSS-Feed abonnieren
- Kennzeichnen
- Anstößigen Inhalt melden
I test SD card driver for uClinux with the NEEK board.
When I start the board is OK. (SDHC 2.0 Class 4 4GB) --- Quote Start --- mmc_spi spi2.0: ASSUMING SPI bus stays unshared! mmc_spi spi2.0: ASSUMING 3.2-3.4 V slot power mmc_spi spi2.0: SD/MMC host mmc0, no DMA, no WP, no poweroff ... mmc0: host does not support reading read-only switch. assuming write-enable. mmc0: new SDHC card on SPI mmcblk0: mmc0:0000 SA04G 3.68 GiB mmcblk0: p1 --- Quote End --- When I redownload the hardware and software image to the board, it is error: [Use "Ctrl+ C" to stop last running] {nios2-configure-sof web_sd.sof ; nios2-download -g zImage ; nios2-terminal) --- Quote Start --- mmc_spi spi2.0: ASSUMING SPI bus stays unshared! mmc_spi spi2.0: ASSUMING 3.2-3.4 V slot power mmc_spi spi2.0: SD/MMC host mmc0, no DMA, no WP, no poweroff ... mmc0: error -110 whilst initialising SD card --- Quote End --- I try a few times, it show same error. Only press the power, it show ok in first times. But I use 128MB or 256MB SD card to test the driver. These are ok with "Ctrl+C". The problem is SD card 2.0's problem? Or else? BTW: I aleady used the up to date driver. I update it today.Link kopiert
0 Antworten
Antworten
Themen-Optionen
- Thema als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Drucker-Anzeigeseite
