Annonces
12748 Discussions
SDA line always low (Opencores I2C)
Contributeur émérite II
1 323 Visites
I'm working on "OpenCores I2C" with µClinux on the DBM_3C40 devboard.
As indicated in the i2c_specs.pdf from Richard Herveille, I pulled-up the both lines SDA and SCL to VCC by external resistors (4.7k).
When I scope the SDA and SCL lines with a working system on the FPGA :
- line SCL is always high and I can observe some I2C sequences (adress+R/W+ack)
- line SDA is always low whereas in the "opencores_i2c.v" source file there are some lines about tri-state :
assign sda_pad_i = sda_pad_io;
assign sda_pad_io = sda_padoen_o ? 1'bz : sda_pad_o;
which means line SDA must always be high when not used...
Thanks for your help !
0 Compliments
1 Répondre
498 Visites
HI..Did you get why that was happening becoz i m facing a similar situation ..even though my whole code runs to last and access happens..my sda line is low at last due to which my next access is going wrong. I m not able to get why this is happening. I have pullups on both the lines and code is also working for others.
0 Compliments
Répondre
