SDRAM Pin Assignment issue
http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/biggrin.gif Issue Resolved, used the first option from those mentioned below by freezy, thanks freezy http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/biggrin.gif
Hi
I am using the Altera 1s10 (Stratix) NDK
I am using the full_featured reference design as my base and have added an remote_update megafunction.
I now have an pin assignment conflict for 3 pins of the sdram address bus.
zs_addr_from_the_sdram[1] PIN_W12
zs_addr_from_the_sdram[3] PIN_W10
zs_addr_from_the_sdram[4] PIN_AA11
these pins conflict with the dedicated remote update pins , so i have to move these 3 address pins to other IO pins.
but
i cannot move to a general purpose IO pin since such a pin would not be wired to the SDRAM in the NDK
i tried putting in 3 general purpoese IO pins but i get a verify failed when i download the code.
could you please suggest a solution
regards
pavan
Hi ppk031000,
Perhaps it&#39;s resulted from the conflicting of external tri-state bus between
2 memory devices on your board. Because I haven&#39;t used the board you mentioned,
so it&#39;s just my speculation.I may give you two suggestions:
1)Perhaps it&#39;s because of your carelessness when you created your system,
so reopen SOPCBuilder and the SDRAM component wizard.Now check
the selection for "Share pins for via Tri-state Bridge" is checked or not,
you should *check it* to avoid the bus-sharing result of SDRAM.
2)If the 1) cannot resolve your problem,Go to download or write
by yourself a MUX module for your conflicted pins http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/wink.gif
Don
