SDRAM - trouble !!!!!!!!!!!
I got BIG problem with nios2 project
I design board with SDRAM - developing was ok
After that i start serial production of this board
And 60 boards was maked without any problems
they all work correctly
BUT NOW I start new serial for 200 boards and got problem
with SDRAM memory - all boards hangs after some time
I guess that is SDRAM problem - but i don't know how to be sure about SDRAM timings - is they ok or not ?
All my fits without any reds int compilation reports of quatrus.
What board are you using?
I have with a StratiX II the problem that it crashes after some time, no idea what may cause this error.
are you using the same type of chip as on the first run and on the prototype board?
if you are using a type of chip not included in the nios SOPC builder you will need to set your own timings, these can be found in the datasheet from the manufacturer
also, are you sure it isnt a software problem causing the machine to fill up all its ram?
