Annonces
SOF2FLASH and EPCS16
Contributeur émérite II
1 148 Visites
Hi All,
I've just started upgrading to Q4.2 (with sp1 added) and NIOS1.1 during a project lull
and I'm having a few problems getting my bootloader running (which was previously fine
under the older Q4.1 and Nios 1.0).
Firstly I've noticed during sof download and after pressing the power reset on the cyclone 1C20
board that the FPGA Config Error (red led) lights briefly, something it never used to do before
however the design appears to function correctly and I can download an application which
runs fine on the programmed board.
Secondly, I've added a few lines to a make file that perform the steps necessary to create
the new EPCS download image files coupled with the bootloader files.
during the sof2flash stage of converting the target sof to a flash download file it reports
that the epcs device is:
--device=EPCS16
However the board contains the standard Altera EPCS4 device. Is this normal behaviour?
0 Compliments
1 Répondre
460 Visites
With regards to sof2flash: Yes, this is normal behavior. We are passing in the largest EPCS device available.... at that stage in the conversion process it does not matter which specific EPCS device is targeted; the utility is just converting quartus programming file formats around to something it can use to create a .flash (i-hex) file later in the process that will be programmed to the EPCS chip of your choice.
0 Compliments
Répondre
