12748 Discussions
SOPC Builder, Ethernet, Custom Design and Memory
I have a development kit : StratixIII EP3SL150N
FPGA: StratixIII EP3SL150F1152C2N.
I designed a system which include a NCO. ( NCO MegaCore v9.0 )
This NCO generate a digital sinewave which depend on a "Frequency Control Word" input of the NCO.
I want to change the value of the "Frequency Control Word" (FCW) without the need to load the design in the FPGA again. ( "real time" control )
So, I created a soft on my PC to enter a new FCW and send it to the NCO by Ethernet (link between my PC and the board only). I have used SOPC Builder to implement the Triple Speed Ethernet in the FPGA.
I need your help to the following :
I don't have idea how to connect my NCO with the Triple Speed Ethernet.
I don't know how they must interact.
I read guide about SOPC builder and Triple Speed Ethernet and Nios 2 to have a better idea but I have not .
If you need more precision don't hesistate.
Sorry if my english,
Jeremy.
I never used the NCO, but it seems to have an Avalon-MM Interface
So they won't be connected together but each of the TSE and NCO will interact with NIOS.
A way of doing it is a server socket running on NIOS that will take orders from the computer, then the Nios program will access the NCO registers.
ethernet is kind of overkill to just update the NCO frequency. you can make a small Nios + JTAG UART + PIO system. add some code to interpret some input ASCII from the JTAG UART into a binary vector, and send that to the PIO. the PIO is then connected to the phase increment input of the NCO.
