12748 Discussions
SOPC own component with irnerrupt receiver
I'm using very simple system: Nios, timer and own component.
My own component consist: MM Avalon and Interrupt receiver.
I would like to create external interrupt signal - I use conduit signal.
everything seems to be o.k. (the connections and the SOPC, generation- everything is fine).
but while I run a simple test (Simulation) the timer create a Interrupt but my own module never got it.
I would appreciate any help!
attached my module.
thank you.
