SSH in uClinux
Hi all,
is there a working port of ssh for uClinux ?
Warm Regards
Thanks a lot hippo,
I'm still wondering if I could use ssh to communicate directly with my board instead of cygwin and other Altera stuff.
Any suggestion ?
Warm Regards
--- Quote Start ---
originally posted by mfm@Apr 5 2006, 06:04 PM
thanks a lot hippo,
i'm still wondering if i could use ssh to communicate directly with my board instead of cygwin and other altera stuff.
any suggestion ?
warm regards
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=14053)
--- quote end ---
--- Quote End ---
sorry, don&#39;t understand what you want?
--- Quote Start ---
--- Quote End ---
what I want to do is to bypass that nios-terminal and communicate directly, via ssh, with uClinux to launch my apps. Thus, I think I can let down the cygwin emulator to prevent a lot of errors.
Warm Regards
I would suggest you keep the nios2 sdk shell on cygwin for program loading.
ie, nios2-download and nios2-terminal.
It is the simplest way. And should be reliable, too.
The ssh should used for other purpose.
He wants to get sshd running, just like telnetd, so he can ssh into the board instead of telnetting.
--- Quote Start ---
originally posted by jdhar@Apr 5 2006, 04:41 PM
he wants to get sshd running, just like telnetd, so he can ssh into the board instead of telnetting.
--- Quote End ---
That&#39;s it.
