12747 Discussions
Searching Ethernet MAC with MII
Hi!
I've a serious problem in finding a compatible MAC for Intel's LXT971ALE transceiver.
The reason is simple:
The transceiver has only a 4 bit datavector. But all MACs I found just provide 8 bit or more .....
The MAC just has to provide MII.
Can somebody help me out with a link or a name to search for?
tx Andreas
--- Quote Start ---
originally posted by fuerchth@Mar 27 2006, 02:25 PM
hi!
i've a serious problem in finding a compatible mac for intel's lxt971ale transceiver.
the reason is simple:
the transceiver has only a 4 bit datavector. but all macs i found just provide 8 bit or more .....
the mac just has to provide mii.
can somebody help me out with a link or a name to search for?
tx andreas
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=13821)
--- quote end ---
--- Quote End ---
If you need internal core - try core from OPENCORES.ORG. Data width is 4 bits.
If you are looking for external chip with MII interface try DM9000 from Davicom
dm9000 link (http://www.davicom.com.tw/eng/products/dm9000.htm)
I&#39;m confused as to what you want; do you want a MAC or a PHY? You specified a transceiver, which is a MII compliant PHY (plenty of these).... but then you also say MAC. The LXT971ALE part is a MII PHY, not a MAC... so what I think you want is a simple PHY, such as the DP83848 by National Semi.
ok. first of all, thanks for the replies.
@jdhar:
sry. maybe I didn&#39;t say it clear enough:
I&#39;ve the Intel PHY with MII Interface.
Therefor I need an IP Core to access it via MII. In my mind a MAC with
MII interface would do this job.
greetz
Andreas
then the 10/100 MAC at www.opencores.org is what you want.
