12746 Discussions
Set/Clear a single Bit of a Register
Is there a dedicated (assembler?) command for the nios2 cpu to set/clear a bit of a register, or do i have to use a "read - modify - write" cycle to change a single bit?
thanks
You are right, "read - modify - write" cycle to change a single bit. Just confirmed with a couple others. It is on a list of enhancements though. But I don't know when it will be implemented.
Sorry.
