12748 Discussions
Setting a conditional breakpoint
Is there any way to set a conditional breakpoint in the NIOS IDE tool.
I would like to set a breakpoint during a condition within an if statement.
For example
for(i = 0; i < 0x1ffffff; i++)
Set a break point at 0x1000000
There is an option in the properties menu of the breakpoint (image attached) to set a condition but it does not appear to break if I enter a value in the field.
Is this type of breakpoint possible?
file:///C:/DOCUME%7E1/EBrown/LOCALS%7E1/Temp/moz-screenshot.png
I have never tried setting a true conditional break point in Nios II IDE. However, a technique I have used before with many architectures is to simply add a NOP to your code with an IF statement on your condition. Then you can set a regular break point on the NOP.
So for your example, you could do something like:for(i = 0; i < 0x1ffffff; i++) { . . . if(i == 0x1000000) __asm__ volatile("nop"); <-- set break point here . . . }
The only way such a breakpoint could be done would be for the debugger to break on every iteration and then perform the the required data test - continuing execution is the test wasn't met. I think gdb can do this, but you probably need to find the gdb command prompt!
So putting a breakpoint on a 'nop' is probably easier.
